Gmac In Trouble?
I heard on the financial news this morning that GMAC is having trouble financially and could run out of money soon, and they don't qualify for any bailout money. I also saw a commercial saying that GM will offer employee pricing to anyone who finances through a local credit union. So if GMAC goes under, what happens to my loan?
Well one things for sure.....Your still gonna' have to pay it!! :D
Seriously though...I'm thinking another bank would,or might,buy them out and take over there outstanding loans.
I'll have to ask our general manager here at the dealership if she has any idea what the "latest word" is on GMAC's situation.
Not a whole lot.
The loans will get auctioned off/sold on the secondary market. Make sure you have the original loan paperwork --- always a good idea.
OR... GMAC will be bought, as a whole, by someone.
Federal law protects you from any of the terms changing on ya. That protects the institution AND you.
Only minor glitch is that a load of the paper held by GMAC are 0 interest loans (like mine)... won't make anyone any money. :D
The loans GMAC has on their books are largely sound and good loans. They are running out of money because there isn't a market for commercial paper right now, and big 3 commercial paper is considered toxic (they are NOT alone, BTW).
The other thing that COULD happen, is GMAC could apply for, and receive, bank status with little trouble. THEN they could qualify for Fed funds. AMEX did that, so did GE Capital.
I do not have any loan on mine. :P
Bragger!! :D
:D
:D JP MORGAN / CHASE :P will probably by them since they are taking over the world. This confirms the beginning of the end of the world.
I wonder if they get sold or the paper gets auctioned off, if they would amend there lease practices, to where you could negociate the buy at the end, at fair market value vs the over inflated residual value in the contracts.
GMAC has been pretty much out of business for the past few months. 700 minum credit score to qualify, works for me, but the rates are not competative at all, anyone with good credit would likely be smart enough to go somewhere else for there loan once they see the rate that is offered . The new leases are worthless too, they cost more than buying them now. I can see why they would be on the verge of collapsing. IMO It was a mistake on GMs part to give control of there finacial arm to a competitor in the first place.
:P JP MORGAN / CHASE :D will probably by them since they are taking over the world. This confirms the begging of the end of the world.
Huh? :D
Huh? :D
OOPS! - Fixed
My family and friends have had nothing but problems with Chase & they love to charge fees out the A$$.
Vmax - Can you send the girls in your signature pic down my chimney?
Huh? :D
OOPS! - Fixed
Sure, but I will have to "lube" them up first. :P
I got a 2.9 loan with them on a impala . I wonder if I could get a deal from them to pay it off early,that would be sweet.I did not use gmac on the truck loan went through my own bank 2% lower then what the dealer offered first.
Good question, I have a 3 yr/36 month 0% loan with them on my truck, which I only owe about 8K on. I wonder what kind of deal they would give me to pay it off? I doubt they would offer me anything, but I may have to ask anyway.
Don't worry GMAC is not about to give you any break on money you owe them. If you go to the GMAC website and setup an account, you can get payoff information at any time. All you need is you contract info and you can create an account.
Its not the consumer loans that has them worried, its the financing of the dealers. 75% of all those GM vehicles you see sitting on GM dealer lots are financed thru GMAC. Once the car ships the dealer starts paying interest on the vehicle.
Sorry, did somebody say something? I was looking at something, and thinking of Christmas.
:D
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
