blue-ss-camaro Posted January 1, 2009 Posted January 1, 2009 I have a 1998 GMC K1500 and I Just replaced the fuel lines with brand new ones and fixed the vent line also cause I was rusted. After I replaced the lines I got a P0453 code. I just replace the fuel pump also. That is where the pressure sensor is right? So that should be new also. So what could be giving me this code? also replaced my gas cap too.
blue-ss-camaro Posted January 4, 2009 Author Posted January 4, 2009 can someone please help me with this? I did a search and found nothing on this problem with this year truck. HELP!!!!!!
merlin5577 Posted January 4, 2009 Posted January 4, 2009 Code P0453 if fuel tank pressure sensor. High voltage may be throwing the code. To repair you will need a engine capable scanner and a good volt ohm meter as well as a good repair manual with the repair flow chart for that code. Check first to make sure no wires are crossed or frayed, most likely you have a short to power. Good luck.
blue-ss-camaro Posted January 7, 2009 Author Posted January 7, 2009 so what ur telling me is that noi one knows how to fix this
txab Posted January 7, 2009 Posted January 7, 2009 Code P0453 if fuel tank pressure sensor. High voltage may be throwing the code. To repair you will need a engine capable scanner and a good volt ohm meter as well as a good repair manual with the repair flow chart for that code. Check first to make sure no wires are crossed or frayed, most likely you have a short to power. Good luck. so what ur telling me is that noi one knows how to fix this I'd say merlin5577 got you some info to get you started
blue-ss-camaro Posted January 8, 2009 Author Posted January 8, 2009 well first of all theres no short cause it was fine before i replaced all the fuel lines so i kmnow theres no short. all of a sudden after I replaced the fuel lines there the check engine light
