Fluid Amounts
On my 04 burb
I want to change the rear end fluid and the tranny pan and filter. How many qts do each of them take and can I use the new dextron VI in my 04 ??
thanks Guys
Pastor Scott
Yes,You can use Dexron VI in your '04 (Its approved for all past applications calling for Dexron II/IIE/III)
The tranny will take 5 quarts if your just dropping the pan (This is for the 4L60-E tranny)
The rear-end will take just over 2 quarts (2.15 as per the service manual for the 8.625" rear-end)
2004 CHEVROLET TRUCKS SUBURBAN 5.3L 8-cyl Engine Code [T]
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, W/ FR & RR AC Initial Fill..........16.0 quarts
Cooling System, W/ Front AC Initial Fill..........14.0 quarts
Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
Automatic Transmission, Total Fill
4 speed 4L60-E..........11.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.2 pints
Differential, with 10.50 ring gear Rear..........5.5 pints
Differential, with 11.50 ring gear Rear..........7.6 pints
Differential, with 8.60 ring gear Rear..........4.2 pints <-----This one
Differential, with 9.50 ring gear Rear..........5.5 pints
Transfer Case,NP8..........4.0 pints
Transfer Case,NR3/NR4..........3.0 pints
Transfer Case,NVG 246-NP8..........4.0 pints
Transfer Case,NVG 261-NP2..........4.0 pints
Transfer Case,NVG 263-NP1..........4.0 pints
1. After refill check oil level.
Yeah but he ask how many quarts,Not pints :D
:D
Yeah but he ask how many quarts,Not pints :rolleyes:
I'm sure he can do the math: 4.2/2 = 2.1 qts
:cheers:
I changed my rear diff fluid today. I was able to get about 2.75 qts in the rear diff.
Buy 3, and fill until it overflows out of the fill hole.
I used Royal Purple this time.
Could you specify that capacity in cubic nanometers, please?
And also in hectoliters.
:D:cheers::cheers:
:sigh:
Pete would also like it in afmeters. :D
