Distributor 4.3l 1999 Silverado
micchev99
Thought i had did things correctly. During the tear-down to replace lower intake manifold gaskets, i marked the rotor relative to the distributor housing. But now, on reassembly, when the rotor is aligned, the distributor doesn't insert all the way. It remain about 1/8" up. I can get it to seat properly if the rotor is off by about 30 deg clockwise. I'm baffled. The bottom end of the distributor shaft has bar in it, so it looks like it can be mounted only correctly, or 180 deg off.
Your hitting the oil pump shaft thats what the bar sits in, i trick you can do is sit the dist were you want it and have someone bump the engine till it seat all the way.
thanks for the help ... is there a way to know which rotated inadvertently? the oil pump or the engine? i'm sure that is it, but I can't imagine how either turned ... the truck has been in gear w/emergency brake since beginning. can the oil pump be rotated back using a long screw driver?
The oil pump may have rotated when you pulled the distributor. Isn't the key in the bottom of that shaft off center? I thought it only went in one way.
Yes, you can rotate the oil pump with a long screwdriver.
maybe, i'm just not that familar with the details down there. you might be right, maybe when i first removed the dist i yanked it upward too quickly and the slanted spines began spinning the oil pump, and after disengagment the oil pump kept spinning due to momentum
not following you here ... by key, are you refering to the "bar" that i was refering too? sorry, not sure what you are saying.
Yes you can use a long screw driver but just bumping the engine or turing the engine by had work alot faster and easier. Yes the oil pump will turn when you pull the dist due to the gears being sprialed and when reinstalling the oil pump slot on the shaft will be off. Yes the dist runs the oil pump.
Well... that didn't come out quite right. For some reason I had a brain fart there and didn't finish making the point. The slot that the distributor slips into is the oil pump drive. The distributor is driven by the gear off of the cam. You can easily reposition the oil pump shaft with a slotted screwdriver.
Sorry about that.
thanks ... i found this, but it is for S10s
http://www.netquickposse.org/keeper/distrib.pdf
anyway to get the right pdf for my engine?
If it's for the 4.3 it should be the same procedure. That engine was used in a lot of vehicle but it's mechanically the same.
