New To Forum, New '09, Its A Good Day
Hey guys, im not new to the forum world, but im new here! I had a 2000 silverado 1500 Z71 for 5 years and it finally was time to let her go :'( I spent many an hour working on that truck, it probably has a quart of my blood soaked in it. it will be missed...
Went to the dealer and got a 2009, White, CrewCab, 1500 silverado 4x4. Love it. The new 6-speed is great.
Im looking to do a few, inexpensive, things to start off and need some help. I was wondering where is the best place to buy a leveling kit? I noticed that i dont have torsion bars... that kind of threw me off. So what all do i need to do to raise my front end, yet keep the nice ride quality. After i get the leveling blocks do i need to upgrade the shocks? (if so what ones?).
Also, I want to buy a complete set of service manuals. i did this for my 92 vr-4 and it was worth the $300 set of books. Where can i buy a set? or is there someone selling CD's/DVD's? Thanks for all and any help you guys have to offer!
Welcome to the site and congrats on your new truck.
Sorry I can't help with any of your questions as I am fairly new here myself.
Congrats on the new truck. Rough Country seems to be the most popular. You can find it on ebay for $68. No need for new shocks either. As far as service manuals, Ebays another good place to look for those.
From one newbie to another welcome!
Thanks for the welcome, and the info.
Im taking it back to the dealer today, the key holder/lock thing they had on the window scratched it bad. I didnt notice until i washed it last night. Also, it is covered in rail dust so they are going to clay bar it for me ( im too lazy)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
