99 Blazer 4wd - Mild Miss....
dougg01
So, in the interest of not replacing everything in hopes of finding the actual problem.....since I don't really have the $$$$ to spare:
Mid rpms under load there is an intermittent miss. It's probably there at higher rpms, but I don't perceive it.
Could it be:
plug wires (they look decent in a causual inspection, but are of unknown age and I haven't checked ohms).
cap and rotor (haven't had the cap off yet)
Crank position sensor (someone on another board mentioned that to me as a possible cause).
So....using your best SWAG, where should I concentrate my efforts for the most-likely resolution. Eventually all of it will probably be replaced, but I'd rather not right now.
TIA :biggrin:
When was the last time it was serviced?
Define 'service'...?
Previous owner had all his regular maintenance done at a reputable shop, but I can tell they weren't as meticulous as I am about stuff.
I don't know when the ignition parts were last changed. I did the plugs a couple weeks ago when I first started driving it.
What spark plugs did you use? GM engines seem to hate anything but OEM replacements. I tried using Bosch Platinum +4 plugs on my dad's old '99 K2500 Sierra with the 7.4L... BIG mistake.
