String Trimmers
Does anyone have commercial experience with string trimmers? I need to get a new one and was wondering the pros and cons of some. I was leaning toward the Stihl FS90R, any thoughts? Good torque, easy of starting and trimmer line reloading.
nothing on the commercial side but I have gone through 3 (worn out pulls) got ticked off and bought the new electric start craftsman. Its great no pulling just plug it in and push the button and it starts right up.
Is this for actual commercial use, or do you just want something with commercial qualities for your personal use? Either way, I'd recommend the Echo Srm-210. Used them for years, and I love them. They start REALLY easily, too!
I have had good luck with the Echo trimmers from home depot. I have never used any of the others you have mentioned.
Some of those are completely different animals than the actual commercial ones. If you're looking to buy a commercial brand, I would strongly suggest going to a local dealer. You might pay a little bit more, but when it comes time to service the equipment, you'll be glad you didn't buy it from a big box store.
I'm not going to use it for commercial work but I do have 6.5 acres to cut and about half a mile of fence line to run along with about the same in a ditch to keep trimmed. I hear the new 4 mix units have some great low end torque.
stihl or echo for sure.
both of them start easy while cold or hot.
Nothing pisses me off more than a small engine that won't start :lol:
I've been know to throw a chainsaw 30 feet in a fit of rage :smoker:
I mow 7 yards as a part time job in the summer and I use Echo for blowers and string trimmers
I am 6'7" and I can't use those trimmers with the bent shaft, kills my back
I love the straight shaft for running the edge on sidewalks, I can flip mine sideways and walk and edge at full speed :lol:
I'm going to swing by the Eco and Stihl dealer today and check them out. Thanks for all the info!
I have used a few brands over the years and Stihl is by far the best, plus the local Stihl dealer here provides excellent service and great prices.
Stihl is one of the best you could ever have. :smoker:
:lol: Stihl here!
Oh....And don't forget the John Deere tractor as well!!!! :smoker:
I'm a big fan of Stihl also. :smoker:
My dad has a John Deere weed eater on the farm. It's probably 15 years old or so and still runs like a beast. It's more of a commercial unit; you have to wear the 5 point harness with it. It's probably 12 or 15 feet long. :lol:
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
