Ugh I Got A Speeding Ticket!
Mckenzie
Well today i got my first ever speeding ticket. I was going 63 in a 45. I had just got done with 4 hours of class and was hella hungry so i was going to get me a billy barou at moe's. I noticed the cop as i was going down hill so i began to slow. I noticed in my rearview that she pulled and put her lights, so i pulled over yada yada and i got the ticeket.
My question is, my roommate said to ask for a trial by jury, and that the charges would be dropped rather than have to get a jury, b/c the ticket is for $81.00. Will this work?
My dad told me to go by the magistrates office to see if they will reduce it. He said to just tell them that im froma different county and unfamiliar with the roads
Can't really answer your question but around here if you go to court and fight the ticket and lose, which is more than likely what will happen, you have to pay the fine plus court costs. I doubt the 'jury' trick will work.
Trying to get it reduced might be a better idea. All they can say is No.
Trials are not run like a business. They don't care about profit/loss or return on investment.
I use the old standards... were you actually doing what they charged you with? If yes, then accept responsibility for your actions.
Yea i was going 63, and i accept full responsibility, but if there is a way to get the fine reduced or thrown out, then i don't see anything wrong with that
How would you get it thrown out? Claim the officers speed gun was whacky? Right now, most cities/counties want every penny they can get out of you. If you ask for jury trial, it'll be put on the docket to be held when they have other cases for a jury. I've served several times on Municipal court juries. Don't know where you are, but you might be able to take Defensive Drivers course and keep it off your record. You'll pay court costs and the cost of the class. But no ticket on record and a possible 10% discount on insurance if offered in your state and insurance company.
In the past, I sent in the ticket pleading "Not Guilty"....State Trooper met me in the court room and said he would reduce the speed from 70 mph to 60 in a 55 zone....knocked down the fine a bit. If you then actually have to face the court, state you were unfamiliar with the area and did not notice the change in speed limit. Now, I'm not saying it'll work...just my past experience.
Just ask if they can reduce the fine and pay it whether they do or don't. You admitted you were speeding. Don't lie, just be honest and take responsibility.
Dude its $81 haha. my tint tickets are $115 and my last speeding ticket was $145. You were speeding and just pay it man. Its low.
Couldn't have said it better. Don't speed in the city, period. :cool:
Only $81?!?! Just pay that... My ticket for a 73 in a 65 was $185... Just pay the $81 and be done...
You can have what they call a "bench trial" where there is no jury, but only a judge. OR you can request a jury trial if you wish. EITHER WAY if you are found guilty you will have to pay for court fees which can be UP TO $500 or more.
Plus there is the whole concept of having to present your case. If you get a lawyer your looking at big bucks. I would suggest paying the ticket unless you know FOR SURE you have a good case. Otherwise you will be wasting time and possibly a shit-ton of $$$$. :cheers:
Edit: Also, I highly doubt you will get a decrease for "not knowing the speed limit".
im in south carolina, and im going to go talk to the magistrate to see if they cant lower the fine or make it so their wont be points taken of my license
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. Per temperature charts, the low side is low (should be 30-35) and the high side is a little high (up to 170 per chart). I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   The static pressure at room temperature is dead on, before and after the charge. Both high/low equalize after some rest.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
    • I call B.S. when I first moved to Texas my first house would only cool to 80 with the Texas heat. The AC tech said it was normal at 100 degrees outside. I remodeled the house put in a new AC. I could hang meat. My cars may need recirculating to start. Once moving it switches to regular AC and I could hang meat. Living in Texas no one would put up with only 20 degrees difference.
    • AC in home or auto only cool down 15-25 degrees from outside temp, but what will help is to put the ac in recirc mode this will recirc the Inside cabin air rather then trying to cool down the outside hot air, I always have mine in recirc mode.
    • Found the fix for this.  Untightan the bolt just below top linkage on the steering column, turn assembly left to reduce space between the two linkage rods at the steering column, tighten bolt.  Made a big improvement.
