How-To: GMT900 Tow Mirror Install.
So this afternoon I installed the towing mirrors in my 2011 Silverado. Lots of folks have asked about a guide for this so I did the driver side to get a feel for what needed to be done then I photographed the passenger side work. Hope this is a help for folks. I have a ton of photos so I will probably have to break it up into several posts.
I rolled down the window for this to make work easier.
The first step is to remove the sail panel that is behind the mirror. I used trim tools for lots of this, they are a huge help. Pry back the panel gently so you can see the trim clips, then pull there. As a side note, the bandage on my pinky and the dried blood should serve as a reminder that trim pieces can be sharp. Be careful. :uhoh:
Here is the panel removed. Use care when removing the clip from the door panel as that one is flimsy and I could see it breaking easily,
Using a small flathead, carefully pry the little square on the door lock knob out. It pops straight out when you pry against the little notch and then it can be lifted off.
Lock knob removed:
  • Replies 66
Using a small flathead remove the small trim cover behind the door release. There is a small cutout on the panel at the bottom for removal but honestly it seemed to come off easier when prying from the top (I did this on the driver side before I knew about the cutout.
Panel removed. Note the locating pin on the piece as well as the corresponding hole on the door panel. Go ahead and remove that 10mm bolt as well.
Use a trim tool to remove the panel under the armrest.
Panel removed
This is a notch at the bottom of the angled door pull. Use a trim tool in there to pry the piece out. It is pretty snug so I used the tool to push the trim out some then pulled it off with my other hand. Just work your way up the trim to remove it.
Backside of trim:
Remove the two 10mm nuts you just uncovered. One up top (hard to see in the photo) and one at the bottom.
Go back and remove the bolts under the armrest. Dropping bolts into the door sucks so I loosened them and then spun them the rest of the way out with a magnetic pickup tool.
There are a total of 5 bolts you will remove. There are two types- 3 normal looking ones and 2 collared ones. The collared ones go into the slanted door pull.
uOrphoY.jpg?1
Pulling the door panel can be a bit scary if you've never done this work before. The clips are TIGHT. I started with a wide trim tool in the bottom back corner of the panel and pushed the trim back so I could see where the white pins were. Locate them and pull in that area. There are several along the back side, bottom and front side of the door. Once all are loose, lift up on the door pane and pull it back SLIGHTLY. There are all sorts of wires still connected. I lowered it and basically supported it with my knee as I worked, but you could stack something under the panel to hold it.
Remove this foam and set it aside. Use care as you will be re-using it.
The next few steps were tricky to photograph because it was extremely tight quarters. This is the back side of the mirror, follow the wire harness to the door switch panel and unplug it. This is tricky because you are working blind.
Once the plug is disconnected there are three of these harness anchors to remove. They're easy to spot as the harness has tape around them. One is hard to get to as it is behind the bare metal door brace. I used a forked trim tool I bought from Snap-On back when I worked for the dealer but needlenose pliers will work too. Be **VERY** careful fishing the mirror harness through the door. I broke the locking tab on the plug when it got stuck on my new mirrors. Thankfully I was able to repair it somewhat to make the connection secure.
The mirrors have 3 10mm nuts holding them on. You'll need a deep socket or nut driver to remove them. Don't drop them into the door! After they are removed. the mirror is still held on by some very stubborn spring pins. Give that mirror a solid tug or two and they'll pop out.
This is the backside of one of the old mirrors. The foam on the driver side stuck to the door. Remove it as the new mirrors should have new foam.
Push the new mirror on. You'll hear a click as that new spring pin sets into place. Tighten down the 3 nuts you just removed previously. Route the new harness like the old one, being careful not to damage the plug like I did. Test the new mirror. Put everything back on, making sure none of the door cables or wires were dislocated from the panel being removed. You'll need to hook the door panel over the top then work your way around to seat the clips.
A few random notes on installaiton:
The folded tow mirrors were VERY stiff to fold out. I almost called the seller to make sure there wasn't some trick to unfolding them. There isn't. Just pull hard. There are two stages- mine are angled back some but they can be locked fully out as well. And of course they extend a good bit.
One weird thing I encountered after installing the driver side was for the first 3 blinks of the turn signal, there was no "click". The lights worked but no noise until the fourth click. This went away once the passenger side was installed. I don't know if this was because I had one signal and one non-signal mirror attached or what. Everything works fine now.
Some after pics:
That little guy is BRIGHT!
That's all I got. I hope all this work helps someone someday. :uhoh:
nice write up!
did your original mirrors have the turn signals in them? if i don't have them now, you think it is plug-n-play if i get new ones with the turn signals?
The original ones were power glass/manual fold with heat and these were a direct install. From my experience and from what I read on others installs the signal wires are already there if you have power and heat it seems. Ryan swapped out to a set of the normal style mirrors with signal (LTZ/SLT mirrors) solely for the signal repeater so you should be fine as long as you have the mid line mirrors, RPO DL8 I think.
  • 4 weeks later...
  • 3 weeks later...
New mirrors are now installed and on the truck. Once you get the lower mirrors adjusted, there are no more blind spots, plus you can see around your trailer. One thing I didn't realize when I ordered the mirrors is that they magnify cars so that they look a lot closer. I'm sure I'll get used to it eventually. The turn signal LED's work great, the mirrors don't shake, and the truck still fits in my garage. A great upgrade.
Did you already have the heated, power, and turn signal mirrors? My code in the glove box say DL3 but I have all the options except the memory and park assist on my mirrors.
I had heat and power only. On mine the old mirrors were one plug as were the new units. Everything was plug and play.
**I also wanted to add that I noticed a bit of vibration on the driver mirror the past couple weeks but between the near constant rain and work I only go to dealing with it today. I pulled off the sail panel and got a turn or two out of the mounting nuts. This seemed to cure it. I suppose the foam compressed some since installation.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
