Tranny Cooler Lines
Am installing a Hayden aux tranny cooler on my 07 GMT900 Silverado. I will install it in series with the OEM radiator cooler. I looked at my sons 2005 Z71 Silverado with the 5.3 and the routing from the transmission goes to the bottom of the radiator cooler, out the top of the radiator cooler to the aux cooler, then out the aux cooler to the transmission.
My question is: the inlet to the bottom radiator cooler is the tranny discharge and the line from the aux cooler back to the tranny is the return?
If this is correct, then is the GMT 900 routing the same as the GMT 800?
I want to make sure that I install the aux cooler downstream and in series of the radiator cooler.
As it appears I will only have to cut the top 3/8 line coming out of the radiator to put the aux cooler in series.
Thanx for any help guys.
Many people run to the aux cooler first. This allows the radiator to "re-heat" the fluid. This is good when the truck is cold, in the winter, or both.
Look at this post.
http://www.gm-trucks.com/forums/index.php?...st&p=838567
Edit: If you don't already have the small factory installed cooler then the pic doesn't help much.
Personally, install your new aux, cooler after the radiator cooler. No need to reheat the fluid in LA.
Hook it up through the radiator just like the factory does.....winter 2008 in south louisiana :nono:
Global warming in LA. :nono:
Still no need for reheat in those conditions. :D If anybody is concerned about too low of temps, then you can get coolers that have thermostats that will bypass the cooler, sending fluid back to tranny. Also you can buy thermostats to add inline on models that have no such feature. As stated the factory has chosen to put their cooler inline after the radiator, so installation of aftermarket unit can be done the same.
It's been said many times here that you run to the oil to water cooler first. No OEM or aftermarket system works any other way. If you reheat the fluid, you're heating it to 210 which is a waste.
My factory tranny cooler setup is from the radiator (out of the top) to the aux. cooler. They put the inlet on the bottom of the radiator so the fluid doesn't freefall and foam (as it would if they had the input going to the top of the radiator).
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
