Wanted: Wix And/or Amsoil Eao Filter P/n For 5.3l Ff/afm Engine
CANCEL!!!
Of course, as soon as I break down and ask...I found it.
WIX: 57060
EaO: EAO50
Full Info. I use their Preferred Customer program because I use a lot of their oil. I've used it for 100,000 miles in my car.
2009 CHEVROLET TRUCKS SILVERADO 1500 PICKUP 5.3L 8-cyl Engine Code [3] LC9 Flex-fuel
FILTERS
Oil Filter: EAO50 Absolute Efficiency Oil Filter
Oil Filter: 57060 WIX 57060 Oil Filter
Air Filter: EAA123 Absolute Efficiency Air Filter: [1]
Air Filter: 42487 WIX 42487 Air Filter [1]
Air Filter: EAA123 Absolute Efficiency Air Filter: [2]
Air Filter: 42488 WIX 42488 Air Filter [2]
Trans Filter: 58608 WIX 58608 Auto Tran Filter [3]
Trans Filter: 58847 WIX 58847 Auto Tran Filter [4]
Trans Filter: 58904 WIX 58904 Trans Filter [5]
1. Light Duty Version
2. Heavy Duty Version
3. 4L80E
4. 4L60E Deep pan
5. Shallow Pan - 4L60E
TRICO WIPER BLADES
Blade Class Driver Passenger Rear
NEOFORM T162213 [1] T162213 [2]
WINTER T372213 T372213
1.OE Design
2.OE Design
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*[1]
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
All Temps......5W-30[2]
Automatic Transmission,6L80.....AF6
Synthetic Low Viscosity Automatic Transmission Fluid
Automatic Transmission,4L60-E.....AF6
Standard Differential, Front 4WD 8.25 Axle.....GL-5[3]
All Temps......80W-90
Severe Gear 75W-90
Standard Differential, Front AWD 8.25 Axle.....GL-5[4]
All Temps......75W-90
Severe Gear 75W-90
Standard Differential, Rear .....GL-5[4]
Severe Gear 75W-90
Transfer Case,.....AF6
Fluids
Power Steering Fluid.....PS
AMSOIL Universal Synthetic Power Steering Fluid
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
1. Oil must be formulated to meet GM standard GM6094M.
2. At temperatures below -29 °C (-21 °F) synthetic based SAE
5W-30 or 0W-30 may be used.
3. GM Part No US 89021671 Canada 89021672
4. Synthetic axle lubricant GM Part no. 89021677 / Canada
89021678 formulated to meet GM Specification 9986115.
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, Initial Fill..........17.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
Automatic Transmission, 6L80 Initial Fill..........6.0 quarts
Automatic Transmission, Total Fill
4 speed 4L60-E..........11.0 quarts
6 speed 6L80..........12.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.7 pints
Differential, with 8.60 ring gear Rear..........4.2 pints
Differential, with 9.50, 10.50 ring gear Rear..........5.5 pints
Transfer Case,BW 4485-NR3..........3.2 pints
Transfer Case,MP 1222, 25,26..........3.2 pints
Transfer Case,MP 1625/1626..........3.2 pints
Transfer Case,MP 3023/3024..........3.2 pints
1. After refill check oil level.
TORQUES
Oil Drain Plug.....18 ft-lbs
Transfer case BW4485
Fill Plug.....18 ft-lbs
Transfer case MP Series
Fill Plug.....13 ft-lbs
Drain Plug.....13 ft-lbs
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
