Owner Of A Great Texas Truck
cromulius
Hey y'all I have a 2001 1500 reg cab long bed ls auto that I have run pretty hard in the constructin buisness I have and its been great. I changed the torsion bar cams to bring up the front a little. I had the receiver changed to a 10,000 pounder for the dump trailer. I also added some overloads to keep it from dragging on driveways at the trailer hitch when loaded and I loaded it a lot. I have since removed the overloads and now it seems as though the springs cant hold as much as they originally could but that may just be me not remembering properly. I now have a quad cab dodge with a cummins so this 1500 is just sitting around. I guess I need to sell it but its not worth much and seems like a shame since I feel I could get 250,000 miles out of this truck. It has 167,000 now with only routine maintenance and a replaced alternator, sway bar end link and the push button 4x4 switch. I also changed the front shocks when I raised the front to fit the 285's. This is no cummins truck but has performed flawlessly pulling very heavy loads with the engine reving high to get up the hills. She has been great. I cant believe the stock auto trans is still kicking with all this heavy towing. When she wasnt working she towed the boat to the lake and I never did baby her unloaded cause I like to go fast also. Anyway hello guys I am here to solve a issue she has now but I will post in appropriate section.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
