This is my 2009 Chevrolet Silverado LT with a 5.3. Got it in March 09 and loving it. Recently installed a 3inch suspension lift (not pictured, I'll post some later). I tow my 2005 Angler 204fx.
The Toy:
The Rig:
2009 Silverado LTZ WDE with my Yamaha Rhino - only pic I have of it hooked up to the truck (its now painted white diamond, has HIDs and a nice sound system).
I plan on buying a boat for the summer time, will post pics of that later on!
Nothing crazy. Just a aluminum center console and a 12' enclosed with various toys. Also hauls the most important thing...@SS!! Well, not really, its slow :o/ I am also adding some new parts to rid the rear end sag when towing. I can't stand it!!! To be honest, I kinda miss it when it was stock.
Edited by J-man67
I don't have that many pics...I will post more tonight that are on my external hard drive.
sorry the details...
2001 PowerQuest 26 SLS
454 Big Block with str. pipes out the back.
about 6000 with the trailer and all. I am at my limit with this truck...anything more then 7000 i am upgrading to the 2500 HD with the D-Max.
I have a 24 ft. enclosed trailer that I haul my 72 Monte Carlo in, also I have an open trailer that I haul my Rhino or go carts in.
Here is a good one.. Used the budget on the truck. Trailer might come this year.
Love the truck 5.3 6speed 14mpg at 65-78mph
Just barely fits :thumbs:
Yeah it runs ;) 11.33 on a 2.0L Current USA record holder.
I tow my 21' Challenger. Boat is 2500lbs "wet" and trailer is 1500 or so. Truck pulls it quite nicely.
The boat also runs really well too....
Edited by Ryan00TJ
I'm currently towing a 27ft travel trailer, but hoping to get into a fifth wheel soon (hence the truck in my sig).
Truck pictured was my '02 YukonXL. I'll have to make a point to take a new picture this spring.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
