5.3 Question
I have a 2004 Chevrolet Silverado 1500 Z71 with a 5.3 Vortec V8, the engine is really messed up and is going to need replaced. What year, model, etc. 5.3 will fit in my truck???
Any '99-07 (Classic/GMT800) will fit. Since you're having to do an engine swap though, you might consider upgrading to a 6.0L instead....
You might consult the search feature for more pertinent information.
Don't you need a beefed up transmission for the more powerful engine with more torque? Will a standard 4L60 unit handle the torque without adverse effects?
And if I was to put a 5.3 out of like a 2001 would there have to be any computer/wiring harrness changes??
Same with the 6.0 would I have to make any modifications to make it fit, or transmission or the wiring harrness/computer??
Could I put a 5.3 out of like a Trail Blazer, or a Tahoe, Or a Avalanche etc. etc.
trail blazer with a 5.3 a? show me one.
Yep, since 2003 you could get the 5.3 as an option. Then in 2006 I believe you could get an SS with the 6.0.
Yup. The extended length TB and Envoy were available with the 5.3L since 2003, then in 05 the Envoy Denali had the 5.3L, in 06 the regular length TB got the 5.3L, and the TBSS came out with the 6.0L LS2.
Do you care for fuel economy? You'll notice a drop in mileage for 6.0 vs a 5.3 motor.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
