Similar thing happened to me. Manual transmission mode didn't help. Transmission temp 190-203. Next day after transmission cooled, everything was fine. My check engine light stayed on. Had the code checked. It was a valve body failure which was repaired under warranty (5 yr/60,000 mi for gas).
This one is pretty easy. Its basically if you have traction control/ Stabilitrac (RPO JL4) or not. If you do, there'll be a TC button on the dash and an amber indicator in the instrument cluster. Additionally, there will be if there are two separate brake lines at the rear axle coming from the frame, as opposed to one brake line that T's off at the rear axle to feed both wheels.
If you’re interested in any cowl pod lights, I can recommend the Parkwood Welding mounts. Offhand, I only recall one other option from a place in Arizona that was waaayyy more expensive. I have a pic of my truck with the lights in a post, here.
Yes; I have a Banks rear cover, and a PPE front with sensors. This weekend I hope to get them heated-up. I’m not planning any towing in the near future, but when I do (and anything notable is observed), I’ll make mention of it.
