Need Help Fast. Rim Question
I found a good deal on rims and tires. The guy says they fit 99-06 Sierra's. I have an 07. Is there a difference in the 06 and 07 ? He said maybe its a backspacing or offset issue but I dont know.
I assume GMT900 for the OP. It should fit. Never measured backspacing though.
unless you can find out the width and backspace (or at least the make/model of the wheel), the best you're going to get is "maybe".
If they are 9 or 10" wide with 4.5" backspace I wouldn't bother with them. if they're 9" wide with 5-5.75 backspace then they'd probably be worth it.
Is the guy local? Bring a floor jack and a tire iron and just test fit em :thumbs:
  • 5 years later...
They will fit, get them ASAP.
ASAP? I'm sure he would have enjoyed having your input 5 years ago when the post was originally made.
Hahahaha
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
