What's Everyone's Avergae Mpg?
so, what is everyone getting for MPG's with their truck? I have a sierra 2500HD extended cab 4x4 with the 6.0 liter V8 and I average around 12.8 MPG. I find this number to be pretty good, considering it's a multi-ton 4x4 that has the aerodynamics of a parachute. I have gotten up to almost 14 before on a long trip cruising on the hgihway. Although, I will say, when I bought it from the GMC dealer, they told me I would be getting north of 16 with it, so I wanted to see if anyone actually came close to that with theirs.
I have 03 ex-cab silverado with 5.3L i average 12.6 - 13.9 city and 15.5 - 17 mpg highway. but I got 285's for tires and I like to get on the gas a lot. Thats with 93 octane. Only my 2nd tank of 93 tho. Im happy with my MPG. Anything under 10 mpg will start scare me, lol.
That's about what I get with my '04, 2500HD, CCSB, 265's, 4x4 with an 8.1L. On the highway I can get in the 14's if I baby it. With a 6.0L I would expect a little better than you are getting but it depends on how much city driving you do and it you idle it allot or warm it up in the mornings.
DEWFPO
9-10 in town and 13.7 was my best on the hwy.
That's still a lot better than my deuce and half (about 5-6 MPG).
2008 GMC Sierra SLT E. Cab Z71 with 5.3L w/AFM (non flex fuel engine)
Average over 25,000 miles is 16.7 combined. That includes driving in AUTO (4x4) during winter for about 5 months.
That is slightly less that my similarly equipped 2004 GMC.
I dont know about you guys, but it seems the harder i run it on the high way it gets better mileage. Everyone says keep it under 2 grand but i beg to differ. i've done it several times and it was a pure and total waste. Made the same trip yesterday, running the shit outta it and i used half of what i used when i was under 2 k going 55. I'm talking keeping it wound up around 90. It just blows my mind.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
