Bed Pockets
Guys had a question and thought maybe someone could give me some help. I had bed rails on my truck that installed in the pockets on side of the bed. I had to remove them due to the cover I installed on my truck bed. I was trying to find out if there was some sort of cap or anything that I could cover the holes with? Any help would be greatly appreciated. Thanks in advance.
Yes, stop by your local metal supply store. Pick up a 4x8ft sheet of like gauge sheet metal return home and custom fab replacement panels. Sand way all paint from area TIG or MIG in replacement panels using a tack method all the way around with the MIG or just lay a nice bead around with the TIG. Grind smooth, skim coat with filler. Guide coat and sand to insure smooth, if not re-skim coat, then re-guide coat. Prime. Paint. It is NOW SMOOTH..
But back to what you were asking I have not seen anything that will work less what I have said on this post above. Will work on the bed rail pockets with a cover installed.
Jbo
The GM retractible tie downs are chromed, stick up just a bit above the rail, and are actually useful! They work well and actually seal with my folding hard tonneau cover.
Truxedo makes a set also, not sure if they fit the GMT900s or not but are listed for the GMT800, I think they are something like $10 for a set of 4 (at least thats what my local shop said). They ordered a couple of sets and I'll let y'all know if they fit the GMT900s or not.
+1 for the retractable tie downs... I have them on my truck, think they are made by bully but they are a loop that pops up / down...
Tonneau closes right on top of it flush.
Thanks for the help. I was trying to find out if you knew where I could get the GM product?
GM makes(markets) some stainless retractable tiedowns that are tidy but add a skosh of bling.
yep that is them. The machine screws clamp it in very well,easy installation, rubber sealed. Not designed for say a motorcycle tie-downing. More like cargo net or misc. tying things down like an awning/tent.
  • 1 year later...
how flat is the 12498613 hooks when folded away? I don't have plastic bed rails and don't want a "bump" in the rails. Are they flush flat in the bed?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
