Got The Painted Bumper Installed!
I installed my Painted Bumper on the truck today after I got home from getting my Black Bear Tune. Heres some before and after pics. Let me know what you think.
Very nice! I think it looks 1000% better than the chrome that was there. I never knew it was so much work changing out that bumper! Good work! Did you do the painting or did you have it done locally? If you don't mind me asking, how much did it set you back? My front has plenty of rock chips so I'm toying with the idea of getting it repainted.
it isn't.......when I put on my fog lights, it was literally 4 bolts that hold the bumper on, 2 At the frame and 1 on each side.
headlights don't need to come off, and only grill & cover above the radiator, and the air flap you see in the lower middle of the pics needed to be removed.
Now, only additonal thing would be to disconnect the fog lights, and then the bumper & endcaps come off as an assembly.
Does look good tho.......
I am still deciding between doing this and getting the SLP cover and going that route. I do like the way the SLP cover covers most of the black under the bumper tho, as well as getting rid of the seam between the bumpers metal and the bumper plastic, but not a big fan of it just being taped on.
I agree, I think you did way too much extra work. I did the fog light kit and it wasnt bad taking the bumper off. The only thing you need to remove is the grille which takes 5 mins and the bumper is held on with 4 bolts. But looks great man!
Looks way better than before, now it looks like an LTZ Silverado. Next you should get the painted to match grille, that is what I need to add to my truck.
Looks even better on the truck than it did in the box in the bed of Rich's truck! :chevy:
:seeya:
Yeah,It didn't exactly match my truck :)
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
