Newer Silverado
I was told 07/08 silverado's have had recalled rotors by a friend, my 08 with 14,500k is starting to have squelling brakes.
Anybody know anything!
No,Not true...There is no recall on the rotors.
I know mine squeal too and I only have 54,000 Kms on it...but have squealed pretty much from the start
Mine were warped at about 6000 miles and the dealership turned them at 9000 miles when I went in for an oil change. They are much better now but still a subtle pulse when I apply the brakes at highway speeds. I'm guessing this will be a recurring issue.
hmmm they probably shouldnt have changed the brakes from the gmt800 trucks... the 800's brakes are amazing they last forever..
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
