Factory Window Tint %
Truckin2003
guys on my Sierra 2500HD Classic the back door windows and rear window are factory tinted. What color and % of tint do i need to match it?
Thanks
It should have a label on lower corner. Typically says something like 19% +/- 2. I'm not sure exactly I'd have to run out to the parking lot and check.
15% comes to my mind, but I'm not absolutely sure.
Thinking the same near 20%. Friend of mine went and got his 08 d-max, the front windows done and they did 20% on it but I think it looked a whole lot darker than the back windows on the crew cab. Also if you go to a place that tints they should be able to check it for you to get it close. I got a regular back that wasnt tinted at all and did the back first with 20% then came over with 5% later, then did the fronts at 20% and he checked the fronts before I left and it registered 13%.
I have 3M 20% on mine. It's not perfect but it's pretty close. You can only tell from the inside anyways.
A good tint shop will have a light meter and can tell you in about 3 seconds....but I am also pretty sure its 20%.
as for color...pretty sure its smoke.
