Gmt-900 Tow Haul Mode
Ok I have used tow haul in my old 2000 and my 2008 Tahoe. I used it for the first time today in my 2010 Silverado. Hauled a bunch of wood (2x4's, 4x4's, and fence pickets). Dont know how much weight but it was plenty. Well I used tow haul. When I would come to a stop light or stop sign the truck would slow down and the rpm's would rev (engine braking) which would help the truck slow down. Is this normal. My two other vehicles have never done this when towing or hauling. It just changed the shift points basically. Is an engine braking system used in the GMT-900 tow haul mode? It worked great I must say.
I think its normal. We had our trencher at work behind our 09 2500HD and we were going down a steep hill and it downshifted and rev'ved up to 4,000 rpms or so...scared us a little at first. But like you said it worked great! And will help save brakes.
Yea at first I was like uh oh when it shot up to 3500 rpm's and I was braking. Seemed to take alot of stress off the brakes.
Yes, I used mine first time the other day...good load and hills, stops signs etc...did the same as you describe...I did not care for it and just went to manual shift and stayed out of 5th and 6th...would have used 5th if much hwy speed and low hills.
Normal. It's because of the 6L80E transmission, I believe... the 4L60E trucks don't do that.
Makes sense I didnt even think about that. The Tahoe and my old truck did have the 4 speed.
Transmission downshifts (grade braking) is definitely a feature of the 6Lxx transmissions in tow/haul mode.
Doesn't anyone ever read thru the owners manual?
When I bought my new truck I was so excited that I read thru the whole thing so I would not miss out on any of the new features of my new truck.
FYI if you want to run in v-8 only drop it into M-5.
Well since i already have a 2008 Tahoe not that much is different and I skimmed over it. I wish i had enough time to read it cover to cover.
Also if I want to run in v-8??? My truck is a V-8 (6.2L) thats the only mode it runs in, guess the owners manual didnt say anything about that :jester:
I went to Silver Lake today and noticed the exact same thing. 150 miles each way. 4 quads on a trailer and one in the box. I got 13 mpg's at 78 mphs. It would hit 90 like nothing was there. GM hit a home run with this combo 6.2, 5 speed, 3.73 and 4 wheel disc.
5 speed?
I have noticed it holding a lower gear after I pass someone and let of the pedal. It holds 2k rpms when I decel the cruise when my other trucks would drop to almost 1200
Also if I want to run in v-8??? My truck is a V-8 (6.2L) thats the only mode it runs in, guess the owners manual didnt say anything about that :cool:
Wow! the 6.2 is a v-8...LOL.
"V-8 ONLY"! It is important to read and comprehend the entire sentence. :jester:
When you select manual mode on the 6 speed and select gear 5 it will not let it drop to v-4 mode (AFM). Sometimes that is usefull.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
