Rpm's While Coasting In Neutral
in my 2010 5.3 when im coasting in N they go up and down whant up with that?
Solution: Don't coast in neutral.
thats good except im looking for an explanation not a solution :thumbs:
Your gas gauge should also drop if you put it in neutral while driving. The RPMs are an emissions thing, they must be above or at 1000 if vehicle speeds are more than 15 to 20 mph. Your truck is doing exactly what it should do. :thumbs:
You should never coast in neutral with an automatic. Since you want an explanation and not a solution, I'll leave it up to you to Google why it's hard on an auto to coast in neutral. I'll give you a hint though..it has to do with the pump not circulating tranny fluid.
Yes the pump circulates fluid in neutral...as long as the engine is running.
That's exactly what I was gonna say! :thumbs:
The pump runs off of the torque converter, it has to pump when the converter is turning.
am i allowed to ask y or will i get yelled at? :thumbs:
A little yelling never hurts. You don't have as much control over the vehicle while in neutral.
Besides you can do stupid stuff. Once I was going to put my truck in neutral going 50 and shoved into reverse. That was exciting.
