When To Do The First Oil Change On A 2010 Sierra
I'm an old geezer and haven't had a brand new truck since Nixon was in office. Just bought a 2010 Sierra SLE, it's got 136 miles on it right now. In the old days when ya got a new rig, we'd change the oil after about 500 miles to clean out the metal filings from the machine work.
It's got a Vortex 5.3L V8 engine, what they called the Power Pak Plus Package.
Now as near as me and the wife can tell from the owners manual, we just wait until the truck or the Onstar, tells us it needs changing, so that would more and likely be atleast 3,000-5,000 miles.
I am gonna ask the saleman when we go back to get the license plates, but just wanted to know what you guys say.
Thanks in advance
Joe
Personally, I've always done a 500 mile oil change, then followed the oil life meter there after unless it was warranted. :thumbs:
Thanks guys. I sure was thinking it would be a good idea, doing one at 500 miles. Am I going to need the dealer do this, what with the Oil Life System, this is pretty dang funny, well pathetic, what I have been driving was a 1990 Sierra 3/4 ton and my truck before that was a 72 GMC 3/4 ton Sierra Grande with a 402 big block. I still wanna cry when I think about that truck. Anyway these new trucks are like driving a space ship!
You can change it yourself with no problems. 6 qts. of your favorite oil and 1 filter. You can easily reset the Oil Life Monitor (OLM). Instructions are in your Owners Manual. Enjoy your new truck, Joe. :thumbs:
Welcome to the site too.
IMO its foolish to change the oil before the first scheduled oil change UNLESS you want to upgrade to a high end synthetic. Changing every 500 miles will do absolutely nothing to prolong the life of the engine. Its possible the oil you are changing out is of higher quality with 500 to 3,000 miles on it than the oil you are putting in has with 0 miles on it.
It's good to hear another opinion. Like I was saying it's been so long since I had a brand spankin new truck. What got me to wondering if things had changed was nobody at the dealership said anything about it and there is nothing in the owners manual about doing it early on.
I always follow the 500, 1500, 3000, then every 5k with syn. I have used this method on all of my vehicles and bikes. I have a street bike with 48k VERY hard miles and still running stong with great compression. I also ride/drive everything like I stole it right from the gate. I believe that, and frequent-early oil changes have helped seal everything up great. Just MY opinion of course, but I have achieved great results.
It is perfectly acceptable to drive a new vehicle 5000 miles, and then change the oil every 5K after that. Changing sooner is simply something that makes the owner "feel" better... It is certainly not necessary.
I purchased my truck in late May, new with 46 miles on it. I changed my oil at 1000 miles. I'm about to change it this week at 2500 miles. I'll do it again at 5000, then every 5000 after that.
My change at 1000 miles was to Mobil 1 5w30 Synthetic with a Mobil 1 filter. I think I'm going to invest in Mobil ... as much money as I intent on spending with this company over the course of this truck's life.
But, most importantly, WELCOME!
Seems like the filter would capture any metal particles. If GM says they will warranty the powertrain for 100k miles if you follow the recommendations of the oil monitoring system that seems good enough for me.
You are 100% correct but there are always those who apply VOODOO decision making and convince themselves that they are making superior decisions by following some self created formula. What they do doesn't hurt a thing, but there is no proof that it ever helped either.
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
