Black02silverado Amsoil
Bought some Amsoil stuff from Black02Silverado recently. Went out of his way to make sure i got the lowest price and shipped quick! Don't hesitate to buy your amsoil stuff from him!
Nick freaks me out sometimes.....
Seriously..... the last time I ordered from him, the oil showed up the next day. Like..... he knew before i even ordered :lol:
Seriously..... the last time I ordered from him, the oil showed up the next day. Like..... he knew before i even ordered :uhoh:
No kidding. I get stuff FAST from him. Well...The couple of times I've ordered stuff :(
  • 4 weeks later...
I am not a big fan of the Amsoil company's marketing methods but I think the Amsoil products are definately in the top tier of synthetic oils that are available today! I have also been a member of numerous forums over the years where most of the Amsoil reps are like Amway sales people.......A lot of talk without a lot of fact!
HOWEVER, Nick (Black02Silverado) is an incredible rep for Amsoil! I see him post in numerous oil and filtration threads and what he provides is valuable feedback and very rarely pushes the Amsoil products. All I read here is excellent reviews from people that deal with him directly for their Amsoil products. The Amsoil company needs to learn from his example...let the product speak for itself!!
I will most likely be "talking" to Nick soon about placing my first order with him!!
Thanks everyone. I try to get orders out as soon as I can. To me fast shipping is important. When I order stuff I want it as soon as possible myself.
I do what I can and hope it helps those that ask questions. :)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
