Weird Idling? Anyone Else Have This?
Hey guys,
I noticed today when I stop at stop lights sometimes the truck has a grumble and the rpm's change slightly. It almost feels like a the truck shakes when it happens? Is this normal?? I only have 1k miles on it. :)
Mine has this too, only thing that on mine it feels like its misfiring, but I have never gotten a check engine light yet. Its been like this for about 10,000 miles now.
+1. I think it is telling me I need to buy a 6.2 in the spring when my lease is up.
Hey guys,
I noticed today when I stop at stop lights sometimes the truck has a grumble and the rpm's change slightly. It almost feels like a the truck shakes when it happens? Is this normal?? I only have 1k miles on it. :angel:
From reading on this forum, a better question would be "does anybody else NOT have this?!"
I have heard this being attributed to the tuning of these engines for MPG and emission.
6.2 does it too :thumbs: rest assured it's just the 800 rmp idle speed. When I got my tune done by blackbear, Justin turned up the idle a couple hundred rpms, and smooth as butter. Had him put the idle back down to the stock speed though. Now that I've had the truck for over 8 months I don't even notice it anymore. you want a silky smooth idle, buy a tundra with the 5.7, that's what I had before the sierra and that's why I thought something was wrong with my engine. If you want a real truck, stick with the GM, some of us are just slow learners, but we come back around, Only had the tundra for a little over 2 years. Ride is gawd awful drivetrain power and setup is fantastic, changing the oil sucks, in the tundra that is and just about everything else with it is below average.
Can't say I notice it on mine, but I'd bet if you get gas from various places, you could get bad gas.
Totally worth it to buy the 6.2L but mine does the exact same thing when idling. I think its just the nature of the beast!
Yep, when my 09 was new I went to several dealers and two independent shops and they told me it is emissions driven as they have leaned out the truck at idle to cut emissions and thus also help mpg...
I now have 20,000 miles and it has smoothed some. It helped to go to syn oil and I ran BG 44k at 5m and then now at 20m miles.
Mine does it on the factory calibration. With the custom tune, it does not. Not sure what exactly makes it go away via the custom tune......
Reason I noticed is that I recently reverted back to stock for a month for various reasons, and just got her tune back in her again.
Ya I thought it might have been doing it when the fans come on because it doesn't do it all the time. The a/c puts a load on the truck when there on maybe the fans change the rpm's when they come on to and that what we feel. :eek:
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
