4l60e Transmission Longevity Good News I Hope
the biggest connection i can make to the 4l60 and how long is life is would be maintance...the secondary connection being how it was treated, i asked out of curiosity at the dealer how many of these trans they replace or have replaced and it sounded like it was a rare occurance....but seal failure i guess is common :rolleyes:
  • Replies 63
I got 120K out of a 91 700R4. Would have easliy gotten more but the pump started to leak and since replacing the pump required removal I decided to rebuild it anyway. Too bad it thru a rod 2k miles later :rolleyes:
I think my '94 Silverado 1500 would have the 4l60e. But I'm not 100%. Not to smart on transmissions yet. Anyways, 189,000 miles on it. Fresh fluid and filter every 50 thousand. Other than that never been touched.
I must admit I'm a little surprised at the number of early failures posted here.
I've owned 1 GM vehicle with a 4 speed Jetaway,
2 with TH350,
4 with TH400,
current Silv with 4L60E.
I've never experienced a tranny failure.
2 with TH350,
4 with TH400,
I hope you knocked on wood as you typed!
What's a Jetaway?
To the guys that have a bit of slip on starting out, to me, this is low pump pressure , maybe a dirty filter. I would consider this to be a warning that something relatively simple needs to be fixed. Maybe a modulator solenoid.
How much clutch slippage is OK, ZERO.
Ken
Ken
No this is somrthing they would do when new. And some times they would not shift to 1st and start out in 2nd. usually a flash at the dealer would cure it. My 05 did this a few times when brand new but I didn't leave the trans stock for very long. It hasn't done it since then.
What's a Jetaway?
My age showing. Had one in my '62 Caddy.
Jetaway aka: Controlled Coupling Hydramatic (or dual-coupling Hydramatic).
...we had...a couple of powerglides... :rolleyes:
Ah, yes, the "slip-n-slide" powerglides. Remember them well.
The 2 speed automatics. I broke one in dads 53 Chevy belair and one in my 56 chevy convertable.
03 4L65E with 53,000
shift kit, servo, tune. flushed @ 25,000 will flush/filter in next 3 mo. a big issue is that most people will not come to a complete stop when changing gears, R-D D-R not good..also beware of people who think they can tune. to much line pressure, and trans shift settings not set properly. been horror story's of trans not lasting 100 mi.
IMO- the best things are a shift kit, Vette servo, and a GOOD tune, and regular service..
Yeah, I started doing the shift-kits in the 70s. Lately I just do the servos and a tune. :rolleyes:
  • 5 years later...
My stock 2003 5.3 Tahoe's 4160e tranny lasted me until 80k miles.
Replacement is going on 150k & still perfectly smooth as silk.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
    • Gloss black would look better, but I'd paint match the grill before ditching the chrome bumpers.
    • Mine has done that since new. The colder the worse.
    • Yeah, that's my understanding. The newer trucks are 433Mhz vs the older 315Mhz TPMS. Putting these wheels on is costing me a small fortune, but so far, I'm still OK with it.    Next week the chrome bumpers are scheduled to be replaced with flat black ones. That would complete what the dealer still owes me.
