4l60e Transmission Longevity Good News I Hope
113K on my 04 and still going strong. Filter change at 60K and fluid exchange through the cooler line at 84K.
  • Replies 63
140k with no issues other than the occasional slip off the light. Feels like a converter issue, it only happens every other month or so. As far as I know the fluid has never been changed and I've heard that if the fluid smells bad don't change it. Anyone else heard that?
i do give it a fair share of abuse. lots of heavy acceleration and braking and drifting and offroading.
You gotta treat 'em right bro!
I just put the first wrench to my 4.8 last month. Put a new water pump on it. But other than routine maintenance, that's it!
Easy on the gas and easy on the brakes.... They will last a LOT longer that way. Believe me!
i know i know. but the Suburban was babied every second of its life... never floored or driven hard or offroaded. thats why im confused.
Bought my 07 nb cc in early 08 and 30,000 mi later lost 3rd gear,second tranny had no reverse in winter temps,and that was at 47,xxx miles later.now on the third and hopefully long lasting trans.and all i do with this truck is city and highway drive,no towing or hauling.yet!
140k...fluid has never been changed...if the fluid smells bad don't change it. Anyone else heard that?
If fluid is burnt, you should have changed it a while back.
MHO: Change it now (a couple times); you might be able to save it.
i have a nbs that i've towed with since day 1 - its got 59,000 on it and its still shifting good. i would like to get my truck tuned but i dont want to gm to use that as a out if the tranny fails.
That what mine does. Slips and also feels like its in a higher gear for a moment.
Anyone know if that maxlife trans fluid actually helps with leaks? I have a very slow leak at the front seal and really don't feel like dropping the trans, lol.
Dads 99 has around 165,000 miles on it, and so far it still shifts great. Who knows when the fluid and filter was changed, it was a company truck for a powder coating company, and they ran the guts out of it...
Occasional slip starting from a stop light. Happens maybe a couple times a month. Changed the fluid and filter at 60,000 miles and 100,000 miles. 102,000 on it now. Hope to get a lot more life out of it.
My 05 did that when it was new. It has not done it in 5 years since I put the corvette and 4th hold billet servos in and got a tune.
Yea other than that it shifts great, and it doesn't slip that often. A couple times a month was probably an over-exaggeration. It tows great too!
Had 89,000 miles on one in my Colorado. That truck was abused from the lot. I have 25k on this one, and no problems, but I foresee some in the near future. I ran under-geared for about 20k miles, while towing, off-roading, and not being so easy on the skinny. Time will tell, but as of now, it feels great.
It's not burned nor does it look or smell bad. I am simply asking a question of all you guys to see if anyone else has heard that.
I have never heard that. What I have heard though is not to do a complete flush after 100,000 miles or so.
the experience with the '90s GM trucks (GMT400's) with 4L60E transmissions is that an average life of transmission is 130,000 to 140,000 miles ... beat it up and abuse it you get less... good regular maintenance and keep it from overheating then get get more...
mine died at 131,000 miles (210,000 kilometers) ... but I bought the truck at 126,000 miles and really have no idea about the maintenance it got from the previous two owners.... got a total rebuild with upgrade parts that should, with proper maintenance last longer than the original transmission
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
    • Gloss black would look better, but I'd paint match the grill before ditching the chrome bumpers.
    • Mine has done that since new. The colder the worse.
    • Yeah, that's my understanding. The newer trucks are 433Mhz vs the older 315Mhz TPMS. Putting these wheels on is costing me a small fortune, but so far, I'm still OK with it.    Next week the chrome bumpers are scheduled to be replaced with flat black ones. That would complete what the dealer still owes me.
