Wax While You Dry
I have searched and read a lot of posts on washing and waxing and I am very impressed by the guys that claybar their trucks everytime they wash. Me on the other hand I try to Wash my truck every or every other weekend and wax twice a year. I've never heard of a clay bar untill i started reading here so I am open to that now, but not every wash.
I love the way my new shiny black truck looks and I want to take a little better care of this one. This includes a spray wax or detailer after a wash. The old ford got washed, air dryed and waxed once or twice a year.
I am using Mcguire's stuff otherwise but I would like to eliminate a step and apply the spray wax or detailer as I dry.
Any recommendations?
Also, The dealer applied the lifetime Quantum Paint Protection (Supposed to never have to wax).
Thanks.
check out this site, they have a ton of detailing tips
www.autogeek.net
www.autogeek.net
Auto Geek does have a lot of good info. Justy looking for some personal experience recommendations for a dry and wax.
I've heard good things about the eagle one on other sights.
Thanks for the suggestions
Anyone else?
I also use Meguiar's Ultimate Quik Wax and love the results! I dry off the truck completely first. I'm not sure that you would get the spray wax to hold very well if you used it while drying, but who knows. Be nice to eliminate a step, though. I also use the NXT liquid wax about 3 times a year.
I used Eagle one's Wax while you wash yesterday. I like it but don't love it. I also did my jeep with it which hasn;t been waxed in about a year and it putt a pretty nice shine on it. The Black truck looks great.
    • Hi, New here.  2026 Denali HD.  Just purchased 7/2/26. I am having the same issue.  I just traded in my 2024 AT4, and the truck connected to bluetooth and Android Auto Immediately!  Now, with the new HD, it connects when it wants to, which is usually not at all.  I have to use the usb-c cable to get it to connect.  Bluetooth won't even connect without the AA. Now after saying all that, I'll take a 20 min drive with the phone plugged in.  Stop at a store, restaurant, etc....  Get back in my truck and DO NOT plug the phone in.  The truck then decides at this point, lets connect BT & AA and work perfectly, ie how it should.   I have deleted (forget phone) the phone multiple times.  I guess I'll just get used to plugging it in every time. even though I don't think its good for the phone battery to have it on charge after it hits 100%. I have searched all over.  No one else seemed to be having this issue, until I read this thread today.   thanks for reading.
    • I have an issue with my ignition hanging and I have to tilt the steering wheel to get in the off position. I have used a great key lock spray and it doesn't help resolve the issue. Is this an ignition assembly issue or something else. If anyone has a past experience with this please advise.   Thanks  Heath
    • This is a terrible GM warranty experience, two months waiting for a covered engine swap with no loaner or timeline is not allowed under GM’s courtesy transport policy.Escalate straight past regular support to a GM executive case manager, document every closed service ticket and dealer repair paperwork. File a complaint with NHTSA to force faster action, and ask for daily rental reimbursement while your truck is down. If it’s been out of service over 30 days, your state lemon law may let you pursue a full vehicle buyback.
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • Sorry, I accidentally posted in the wrong language. I'll repost it in English.
