How Often Do Yall Go To The Doctor?
sab316
As the title says who goes to the doctor for the most minor of things or do you wait it out until your arm has actually fallen off?
I currently have what I THINK is strep throat and I've felt like crap all day. I was determined I was going to the doctor in the morning. I ate (for the first time today at 8 p.m.) and took some medicine and I'm feeling alot better and now I'm thinking maybe I don't have to go to the doctor.
As you can tell I'm a typical guy who doesn't go to the doctor until I absolutely have to.
So what does everyone else do?
Last time I went was about 3 years ago, and that was for pneumonia, when I have to go, I can tell. I don't go until I just can't function anymore, as I hate(or am scared of) needles. I've had very few random sicknesses since then, none too bad, and usually only lasting about 4-5 days most, but not worth the doctor's office to me. I hope I never have to go to the doctor again. :rolleyes:
only time i went to the doctors is when i almost cut the tip of my finger off, good thing the bone stopped it, lol other then that i never go, when i sprained my thumb three times, i just didn't use it where my friends will go to the doctor to get x-rays or splinters or casts.
the way the medical sector works is, they want to see you as often as possible or for the stupidest shit,why? MONEY!!
i'm a firm believer in what dosen't kill you makes you stronger, and also that americans are over presribed medication..hell look at kids with ADD and ADHD, pills are a band aid for a problem not a cure..and yes i do have medical insurance
I really never go to the doctor. I can tell you one instance where I've gone in the last 10 or so years. Usually NyQuil and a shot of your favorite whiskey will cure just about anything.
what about aids? lol i'm totally kidding man
Us old farts with Medicare and Tricare can go for FREE. Thank you to everybody still working. That's the "thank you" we Vets really appreciate. I salute YOU for your efforts.
I go in if it causes me to miss work. I think that should be a rule.....If you take a sick day, you better find out what's wrong with you ASAP. We are getting much too lazy.
I go if it's major.. like i can't get out of bed for 4 days in a row, or something got cut off. BAck when i was in my late 20's, i had gall stone attacks for 6 months before i went to the doctor. I finally made an appt. and when i went i felt fine, so the doctor tried to pass me off. I said, nope, i was on the bathroom floor for 9 hours last night, something ain't right! Fix it! 2 weeks later, had my gall bladder out, no problems since. Had one bad sinus infection last year, i just battled it out without antibiotics... i do have a regular doctor, and when he sees me come in, he knows something is up.
I hardly ever go. I don't get sick very often, and if I do it's usually just a cold/cough. Most things can be taken care of with over the counter meds. If I can't get something to go away then I would go to the doctor because it might be an infection that I need a prescription for. I just don't see the point in wasting my time for them to say you have a cold, take some tylenol. Gee thanks.
Hopefully you are supporting your VA as that is where my wife's paycheck comes from :(
I went to the Doc in sept for a sinus issue. All I want fixed is my sinus issue (stuffy all the time). This turned into him wanting me to come back a month later for a physical and tetnus (sp?) shot. It has been over 2 months and I have yet to be back. Guess I have to deal with the sinus issue :rolleyes:
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 522 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
