Project 900
Many members here lately checking up on glitches/problems/ reliability of our 900 series trucks.
So, let's give our purchase date, current miles, and any warranty work done so far.
Daily driver
2010 Silverado LS, 1850 miles, 4.8. Bought June 2010
No issues as of yet. I pulled the OnStar fuse because I hated the incoming messages from OnStar.
No leaks, still drives tight. No road noise.
Front brake rotors have very slight out-of-round pulsation. Has not bothered me enough yet to fix it.
'08 Sierra SLT, 51,000 km, March '08
Fuel Pump replaced
Minor Rattle in sunvisor
Engine Ticks for 5 min or so on start up - No fix yet
Engine burns about a litre of oil every 1000 km - No fix yet, doing an oil consumption survey
Had rotors turned at 48,000 for pulsation when braking
Heavy condensation in one brake light
Other than that, a pretty flawless vehicle.
08 Sierra Crew
Oil pan leak: repaired
Driver's door lock actuator: repaired
Drives the same as the day I bought it. No issues.
10K miles plus some change
Rear leaf springs changed at around 5K miles
07 Silverado 64 000 kms
Replaced both front wheel bearings, left one at 60 kms and the right at 61 kms roughly a week apart.
Heated washer fluid module removed.
07 Silverado crew cab LTZ VortecMax
60,000 miles
Only problem I have had is the sunroof drain plug got clogged and I had a little water leak with a heavy rain. Dealer took care of it though.
2008 gmc 5.3 sle2 z71 x-cab 40,000 miles
all 4 rims replaced due to corrosion
rear bumper replaced due to rust spotting
drivers door hinge replaced
sensor in gas tank replaced
2007 sierra. 40k wheels at 25k due to corrosion. Needs drivers door detention replaced. Front rotor pulse at 30k.
Love it!
08 Sierra Crew, 6.2L. Coming up on 25k miles
Drivers front and passenger rear door actuators replaced (one at 5k and the other around 12k)
Center brake light replaced at 8k (probably tightened too much from factory, spider cracks extruding from screw hole)
Loud body bushing causing squeak/creak sound behind dash. I installed Teflon pad per TSB. Maybe at the 10k mark.
On really cold mornings i'll have some engine knock on startup for the first 2-3 minutes.
2007 V-Max 90,000 miles, bought July Of 2007
Daily Driver
Problems so far
Changed the front brakes three times and it needs front brakes soon.
Changed the rear brakes twice, so far so good.
Stock 17s used them for 20,000 miles, got a set of 20s with the Goodyear Eagle LS2 after and tires lasted 60,000 miles.
Broke the transmission at 80,000 miles, got it fixed under warranty.
Other than that it has been a great truck.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
