Man is it hot here in Wisconsin
Frank S
We're in the mid 90s here. Very uncomfortable! 1zhelp.gif  I'm going swimming. 0000007.gif
What's it like where you are?
It sucks here in NH!!! At our house the temp read 96 on our back deck in the direct sun! Too much for me.
It's in the mid 90's in Houston with close to 100% humidity.
This sucks but it did start raining a little while ago so it isn't quite as bad now.
High 80s with too much humidity here in Illinois.  Sure hope this doesn't blow up into some thunderstorms, sure feels like it could.
Swimming, thats a nice way to cool off.  Much better than fixing the roof on two of our barns.  Galvanized metal gets pretty dang hot in the late afternoon.
I'm sure this won't be popular, but since LT asked, it's about 68 degrees in my little town today.  If it makes those of you sweating feel better, it did get up to 89 on Sunday :o  That's about as hot as I've ever seen here.  The flip side is, 34 below in the winter is quite common, and you may remember my post about it snowing earlier this month.  Cracking a cold one for those of you in the humid 90's and a hard working Jpshostr!
80's - 90's here in Ohio. 90%  humidity last week, it dropped for a coupledays but is supposed to come right back up tommorow. Its hotter than h*ll paintin roofs.Thats what I do paint, roofs barns houses, bins, its hotter than sh*t always.
Hot here in ny to been hot the last few week today it was high 80's same tommorrow friday 92 saturday 85. All last summer we did not hit 90 this year 4 times already summer sucks.
90's all week here in MN. It gets old fast sweating out everything you drink in 20 minutes. Seems like my AC has been on max for a month straight. Those shingles and black tar paper get mighty hot! When it's 100 on the ground, it is 120-130 on the roof.  We try to take breaks every 45-60 minutes to get some water in us. We are supposed to get  cool down this weekend, only mid 80's (still too hot if you ask me). Am I in the Northern most state or what? :)
Tough it out guys and keep the AC on HI :)
Well you northen boys complain about the heat all you want.   :) But me and yZR2k, 76BBSub, and any other members from the midwest/south are probably going to be looking at a month straight of 100 degree + days.....
And you know what, I'll even let you keep all those days!  You always seem to send all that stuff up to us when it is time to bale straw though.
This time of year in South Carolina, we have two types of weather;
1.) Rainy and humid as #### afterwards.
2.) Hotter than #### and humid.
Day OR night.  LOL
Nothing like the middle eastern countries this time of year.  115-120 everyday, 80's-90's at night.  Been there, done that.
(Edited by MountaineerTom 99Z71 at 12:58 am on June 29, 2001)
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
    • Very true.   However.  GM did give those trucks with the single speed case Terrain Mode.  Terrain Mode mimics 4LO minus the gear reduction and torque capability.  It uses the ABS/braking system to perform the operation.  It also gives these one pedal driving (sort of) when in Terrain Mode via the active brake during throttle lift.     Does it have its limitations over a true 2 speed case?  Sure.  But it works.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
