Can't Change Vent/heater Controls ...vacuum Line?
I searched, and nothing came up for the problem I'm having.
Today when I wen"t out to start my truck the windows were fogged up fairly bad, so I put the knob on defrost/floor and went inside to get ready for work. Ten minutes passed, I went outside and the windows were still fogged up! I then noticed that it wasn't blowing out of defrost but instead the dash vents. No matter where I turn the knob, air continues to blow through the dash vents. I couldn't drive my truck to work today because of this. Any ideas? I really would like to save some $$ and do the repair myself if possible. If it is the vacuum line, where is a common place for it to break? and does anybody have a picture or diagram of it?
Thanks!
-Rob
Edit - Oh, and I read somewhere, if its the vacuum line it would normally default to the floor and defrost, which isn't bad considering that's all I use most of the time, except its not and instead stuck on the dash vents. More than just five bucks worth of hose?
my parents had a '02 Gmc Safari and ended up having to replace the vacuum hose in that for the heat...so yeah, they still use it
I had the same issue in my truck for 2 days and it went away. Even when it did for those two days most of the time when I shut the truck off and started it back up again the issue was gone.
Hope that helps in anyway.
A '02 Gmc Safari is NOT a GMT400-800 or 900 and yes the Safari used vacuum but it was introduced in 1985 and the HVAC was not changed, it was discontinued in 2005.
Your control is electronic. Try disconnecting the battery for a few minutes. I've seen this work in the past. If not-you should have it checked out instead of just throwing a new control module at it.
Thats not what you said, you said "GM hasn't used vacuum since 1987 and all GMT400-800-900 use all electronics. From what you said, i took it as gm stopped using it in '87, which is NOT true. I have a friend with a reader, i'll see what comes up.
Raf and gone again, thanks I'll try disconnecting the battery and see if that works!
how would I do a relearn of the hvac doors? Dealer trip? I'm thinking of going in tomorrow to see what they think is the problem. I have the battery disconnected right now, so I'll wait and see if that fixes the problem.
can't find the problem. I've done the reset countless times and nothing, so i made an appointment at the dealership to get it fixed on Wednesday. I'll post what the problem is and how much once its finished. I hope they use enough lube.
dealer tech found a wire stuck in some gears for the defrost/floor actuator. Said it was probably from the first owner (was a lease before I bought it) and he had an electric start installed before. $130 for them to take a wire out of a gear...ouch.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
