Chrome Door Handles
Since I cant order them on my new truck, I was going to buy them seperately and put them on, but GM accessories doesnt list them on the website, and my local dealer website doesnt list them either under accessories either... How much are they and how do I get them...They list the chrome mirror caps, but no handles???
www.yourgmparts.com
I think GM Parts Direct even sells them.
www.yourgmparts.com
gmpartsdirect.com does sell them
Crew-cab Jeff?
Yep Crew Cab Rich..Thanks....
This is another case of GM discontinuing another package that makes sense and creating a more expensive one that you cant use with other options...grrrr
Crew-cab Jeff?
Jeff,
Part number 19213939 is the chrome door handles for a crew-cab.
Check Ebay...there are loads of them there
Do a search for 2010 Silverado, Sierra, Tahoe, Yukon, Suburban chrome door handles and when the listings come up, filter the results to Factory, OEM
If you're checking E-Bay make sure they are the real GM handles and not knock-offs. We have a few trucks in the parking lot at work with knock-offs and while they were cheaper the chrome finish does not hold up.
Your dealership should be able to order them for pretty close to any price you can find. Thats what I did :thumbs: I paid $130 for a crewcab set when I bought my truck.
Crew-cab Jeff?
Jeff,
Thanks Rich, this makes things easier for me to search :thumbs:
Yeah thats what I had planned to do, but I wanted to know about how much they run so I'm not sticker shocked....$130 isnt bad, its less that what I was thinking they would be..Thanks
right next to a chrome gas cap, chrome fender well trim, chrome rocker panels, and chromed chrome found on every old mans truck in my town :lol:
Whats that supposed to mean??? I just want door handles chill out..
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 484 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
