Top Gear Usa: America's Toughest Truck
CHEVY FTMFW!!
http://www.history.com/shows/top-gear/vide...toughest-trucks
This is the Greatest Day in the ENTIRE HISTORY of GM Trucks! This 1983 C/K Stepside Took on ALASKA AND WON! and you know what made it Sweeter? THE FORD Was the FIRST TO DIE! Let us Celebrate with some Victory Burnouts and Rock Crawling FOR ALL!
CHEVY FTMFW!!
I disagree. This show is a week old now so LAST Sunday would be the day to use. :)
CHEVY FTMFW!!
I know, but But Still, That was the Greatest Day in GM Trucks History! It was the Day Chevrolet and GMC PROVED that they are in fact BETTER Than Ford!
i'm happy the chevy won, but in all reality those trucks were modified...i was expecting the dodge to win just because of the age gap between trucks..they should of limited it to a certain number of years..in all reality if they for example limited the trucks to the 90s the dodge would of have the biggest advantage with the danas
To bad the engine was what took a crap. The danas wouldnt help that any lol! :)
I bet it was a combo of the Mileage, the Lift and Terra Grapplers, and I bet the Engine ingested a bit of water in the Crankcase, and it turned the oil into sludge.
Yeah I was waiting for the trans to let go.
that was NOT gonna happen; the Transmission was the descendant of the Legendary TorqueFlite!
The 73-87 GM trucks took MAJOR abuse... I know, I abused the &^$%!!! out of mine for 7 years. The dodge unless it was a 318, i would have expected engine problems. I am suprised the fords front end didn't fall out from underneath it, and the GM probably would have rusted out first
Those 4 speeds are one of the reasons so many think Chrysler has lousy transmissions.
ONLY because people were too STUPID to put the PROPER Fluid in the transmission!
Rutledge CLAIMED that it had a 5.7, when in Actuality, the Ram only came with the 318 (5.2) and the 360 (5.9). and the Furd's Driveshaft snapped on a large Rock.
It snapped because the idiot driving it smashed it into a rock. It was fun to watch but those 3 toolbags broke so many safety rules of off-roading it's not even funny.
When he said 5.7 i went huh? lmao lol :):M16:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
