How Much Do You Use Your Horn?
yukon25008.1
Just curious how often everyone uses there horn.. Maybe its just me being impatient, but i find my self beeping at least once every trip. people just drive me crazy like theres no one behind them.. Or taking like way to long to move from the stop light, sign or yield.
JUST FU>>>NG MOVE!!! :D Or just total confusion.. if you dont know where you are or where your going GET THE F..CK OUT OF THE WAY!
I rarely use it, and mainly it is just when people cause me to brake when I am on the highway when they are merging on and speed up to get ahead and then slow down to slower than I was traveling.
I use mine very rarely. I leave an "out" anytime I am behind anybody - and I go around a LOT of people, but I don't give them the satisfaction of a horn or finger... just me flying by.
I only use it to get people's attention. Usually when people drift into my lane, or dont move when the light turns green. Most of the time its due to texting and not paying attention while driving. I also like to honk when Im driving next to people and I can see them texting on the freeway. Sometimes it scares the hell out of them and they start paying attention to actually driving.
Hell Im only 26, and most people my age cant seem to get by without their phones for 30 seconds. THe younger they are the worse it seems to be. Im a firm opponent of cell phones having more than one feature. Its a phone people, its used for making phone calls. There is no need for constant interaction with other people. You are not going to be forgotten that easily. Hell wen I got my first cell phone in HS I was only allowed to used it in emercency situations. I think that anyone caught using a cell phone while driving should have their license suspended for 6 months and have to repeat their drivers safety course, and have to take a defensive driving course.
Can you tell that people using cell phones on the road pisses me off.
Mostly use it just to get people moving when the light turns green. So many people are messing with the radio, phone or whatever and wait too damn long to go. Some lights in the surrounding towns are stupidly short, even for the primary road and it drives me up the wall when people don't just go when it turns green.
Stock horn never...
Hornblasters conductor special train horns ... somewhat a bunch....
Nathan airchime, K3LA train horn, any chance i get :rolleyes:
I highly recommend these horns to anyone that wants to make there commute more enjoyable! :P
Stock horn never...
Not to be off topic, but are you a member of ZR2USA.com? I recognise the decal on the back glass.
Stock horn never...
I'm on there too (Mike) and had the same reaction so I'd say that's a yes! :P
Cool, nice to meet you guys. My handle over there is Tyhuck. Just in case you were wondering.
:P
Damn, my cover is blown...
No thats not me... ummm, i drive a zr2 tracker... They call me frisco zee :rolleyes:
j/k, yes sir i am over there to... Same username too..
But anyway, i love my horn's :P
enough. iv been starting to use it when i pass people on the right though. i get pissed when im in the left lane and someone is in front of me not passing anybody and wont move over- or if im coming up behind and they move over in front of me and impeded my driving.
at night i'll throw all my lights on instead.
glad to see im not the only one (im 24).
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
