Brand New 2011 Chevrolet Silverado Ltz 1500 6.2l
Baker_one_nine
Hey guys, i've had my truck for a little over a month and have been spending a little time on this site looking for suggestions for aftermarket items.
I traded in my 2007 Chevy Tahoe 5.3L 4 speed, because it just wasn't performing as well as i would like it in the mountains. And i was really looking for something that could load up my motorcycle.
As you can see, my Tahoe was done up pretty nicely, and i did swap the wheels to my new truck.
I have already tinted the windows 20% all the way around, with a 5% strip on the windshield. I have also put on a custom dual exhaust with twin flowmaster 40's. I have a K&N drop in filter for now. I also installed a JL "stealth" box under the backseat that holds 2 10" JL W3 subs and a JL 600 watt amp.
My favorite mod so far though is the Edge CS programmer on the dash.
The wheels are Zinik 22" with 305/40/22 Cooper Zeon LTZ.
I swapped the stock chrome front grille for the Z71 black appearance package one.
Currently waiting on black dominator nerfs, truxedo lo-pro, RC 2" leveling kit, billet bowtie, and silverstars in the mail. Also plan on debadging and doing my tails and rear bumper in the near future.181090_10150136423305731_689475730_8405352_2301720_n.jpg
Oh yeah, i love to clean my truck. And black just looks so nice when it's clean.
I still have that stock front grill, and 4 brand new z71 20 inch wheels with stock tires if anyone is interested.
Yeah i think state law for me says 35% front and like 18% back or something. So i cheated a bit for sure. But as long as you can see in the front windows i usually dont get in trouble.
Sorry the photos suck, they're just off the blackberry. Once i get the next round of goodies on it, i'll probably snap some better pics.
I was very impressed with the 6.2L stock. But you let it breath and damn, better keep the traction control on, or i'll be in the market for tires very soon.
  • 1 month later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
