Weather!
pacodiablo
I like it much better when the wet stuff turns to white stuff, then we snowplow, and make the green stuff. :jester:
ITS SUPPOSED TO SNOW HERE THURSDAY !!!!  :jester:
A snowmobile is looking nice  :)
Luckily our former sgt. who got promoted to our shift Lt. has a set because he's letting is stay in short sleeves for now.  Like I say, you can always put on a #### jacket.  I'm ready for a little snow...especially with new rubber on the corners shortly.  We'll see what winter holds this year.  We haven't had a "real" winter up here in Northeast Ohio for years.
A snowmobile is looking nice  :jester:
Ya I second that... Mine is just begging to be taken out for a ride... Cold is good!!!! Let it snow this year will ya...
Boy I can't wait for the one snow we'll getthis winter (if we're lucky).
I love being entertained by the "professionals" in their SUV Spinning around and crashing into the banks.
Mayb I'll have that truck by then, Even more fun! :jester:
I personally don't like cool weather (I can forgo the rain and dreariness though) but my car LOVES this weather.
40-60 degrees with high barometric pressure and low humidity is optimum for making horsepower!  Turbocharged and supercharged cars like this weather even more!!!
I can tell the difference simply laying into it last week as opposed to when it was 85 and high humidity this past summer.  It just wants to gooo!!!  :cheers:
You guys are all nuts! :cheers:
I can deal with the snow, but not the cold damp dreary rain.  Had to break down and turn on the heat last night.  Way early, usually try to put that off until November 1st.
Give me 75-80 degrees, light breeze, low humidity, no bugs and fall colors 365 days a year!  Is there anyplace where the weather is like early Fall in Upstate New York all the time?  (Besides in my dreams?)
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
