Baseball Finally Here Again!
kjblake40
Anyone else here enjoy baseball? I don't enjoy the NBA anymore and the Hoosiers men's basketball team has not been that fun to watch the past few years, although I think that will change soon. So after the NFL season ends, it's a long couple of months for me as far as sports viewing goes. I love grilling out and drinking a few beers in the evening and watching a baseball game. Go Reds!
Cardinals all the way! hopefully we can hang on to Pujols after this year.
Very exciting start of the season for the Reds! They are picking up right where the left off last year. Winning games at the end in dramatic fashion.
Actually like the local Redhawks independant league games better. Cheap tickets, dogs and most importantly beers
Now Holliday just had emergency appendectomy surgery
really? I havent heard this
13 - 3 Jays looks like it will be the biggest opening day win this year....
That was an April Fools joke by the Twins :uhoh:
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 623 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
