Raptor / F150 Frames Bending..
bogeypro
not a design flaw..
ABUSE by the drivers.
read the full information before jumping to conclusions:
http://www.autoblog.com/2011/07/21/svt-bos...amage-claims-w/
basically you have guys that changed the rear leaf springs with after market stuff, and removed some of the designed safety stops as well as used a tuner to remove the speed limiter, then drove the truck beyond it's capabilities on unknown roads (they did NOT pre-run the course to know where all the possible danger areas were) and bent the frame.
the 4 professional drivers that were part of that run did not bend their frames, the 10 morons that ran the course too fast with aftermarket mods that did bend their frames are now bitching because Ford won't warranty it.
I do not blame Ford one bit for warranty denials, nor do I believe that there is a design flaw if the vehicle is driven within it's design capabilities.
There is just something wrong with driving a new truck like that ........... unless you have more money than common sense!
and this is why other car companies are not building trucks like this... their owners are dumbies with too much money!!!
you can break anything – you can even break a trophy truck..."
The man says it all right there. The differences between the amateurs and the trophy truck guys are sponsors and money. If you can't afford to break something, then don't do it
Ford built the Raptor to be a high-speed offroad Baja monster right from the factory. IMO, you are an idiot if you buy a raptor just to cruise around town and look pretty.
They are badass trucks all the way. I wanted one soooo bad before I got my silverado.
I agree... Ford needs to stand behind the trucks. Their own advertising shows the truck being brutalized. Don't build it if your not going to stand behind it. Lame if you ask me of Ford to blame it on the owners. I'd think the frame would bend the other way when jumping :cheers: When there's many examples of the exact same bend in the frame,... I find it unreasonable to believe ever one of them did the exact same damage. The owners all found the same weakness.
Agreed...
I agree... Ford needs to stand behind the trucks. Their own advertising shows the truck being brutalized. Don't build it if your not going to stand behind it. Lame if you ask me of Ford to blame it on the owners. I'd think the frame would bend the other way when jumping :dunno: When there's many examples of the exact same bend in the frame,... I find it unreasonable to believe ever one of them did the exact same damage. The owners all found the same weakness.
if you read thru the whole thing there is more to it that that.
I happen to know personally (not via internet) one of the 14 that was on that run, all those that have damage were running aftermarket leaf springs, had the jounce bumpers removed, and were running in excess of 100 mph (used a tuner to remove the 100mph limiter). The damage was caused by the over sized leaf springs smacking the frame at the jounce bumper break point, since there was no jounce bumper there to absorb the energy it smacked into the frame..
they modified the car and over drove it through a course/area they were not familiar with, the 4 that did not have damage ran the exact same course but in full stock mode under 100mph.
there is more to it than the first dozen posts elude too.
you cannot expect Ford or any Manufacturer to warranty repair a vehicle that received damage due to modifications and owner neglect, and that is what happened here.
the reason they all suffered the same damage is they all did the exact same thing, over drove the vehicle (recommended speed by the organizers was 60-80mph and those that had damage admitted to excess of 115mph) on a course that they did not scope out and they were not aware of the 2 major cattle crossings that caused this damage.
The organizers of the run had GPS data where marked the bad areas of the course and made that available to those that participated as they had pre-run the course. all 10 of those that suffered damage DID NOT heed the warnings of the professional drivers that ran the event, the 4 that did, did not suffer any ill affects.
again, I don't believe Ford has any responsibility to step up and pay the $800 - $1000 for frame straighting for anyone that modified the vehicle and drove it beyond it's ability.
I can't believe people drive any kind of truck like that and expect no serious damage. That's why you do it with OLD trucks that don't cost a penny and you buy parts, buy parts, buy parts..... Hell, it's scientifically known that our roads are so bad here that they cut the life expectancy of some parts seriously and that's ONROAD. :dunno:
In the picture up top the jounce bumper is what it bent, i don't know what your talking about in regards to that.
From what i read on that forum, the aftermarket springs were made by deaver, and were designed to act like the factory springs in the sense that it would't over-flex and jam up into the frame. I did read somewere that there were stock trucks also having this problem, and even in a advertisment by car and driver (if i remember corectly, there is a link in that raptor forum to it), and it shows the frame bending going over a jump, they don't point it out but if you look closeley at it you can see the bed flexing.
People simply hit an obstacle too damn fast. Ford made a great product with the Raptor but those people pushed it beyond it's limits. Just like you can't take a stock Jeep hardcore rock crawling. And the "but they showed it on TV jumping" is the worst damn argument on the planet. There are sooooo many variables when it comes to that sort of stuff that there is no way to realistically compare it. Right off the bat I'll say most of the ads showed the truck in loose sand, not packed gravel. That'd make a huge difference on landing impact forces.
the deaver spring rate is much softer than OEM, so they bottom out much more readily than OEM.. also at those speeds the rebound is not 11" it's probably 3"-4" at most, couple that with softer springs, excessive speeds, not knowing the course = parts broken.
my thoughts are based on what I know from talking to guys on that run, the primary guy leading the charge against Ford had Deaver Springs and removed his bump stops, several others may not have removed them (as evident by the picture) but all 10 had the Deaver Springs, and even Deaver stated they should have also installed the Deaver Bumps Stops:
notice theirs requires a cross member installed, and relocating the bump stops to work with their springs.
the bottom line is you can't keep the hammer down while going through certain obstacles, you have to slow down at certain ones. You can't just go top speed across anything and come out ok.
again, I don't believe Ford has any responsibility to step up and pay the $800 - $1000 for frame straightening for anyone that modified the vehicle and drove it beyond it's ability.
Your right, I only read the first 2 or so pages, then skipped around. I agree with you 100% :dunno: From the start of the thread, it was sounding like the FJ issue with the frame tearing apart and the Tundra tail gate folding, where the dealer wouldn't admit an issue till they had near 500 complaints and a class action law suite brought up.
The guys over at Pickuptruck.com are riding a poster and Raptor owner named Huck pretty hard
over the bending frame issue. This guy carries on how "tough and invincible" the Raptor is
compared to those POS ordinary GMs and Mopars..................
Hes eatin' crow now !!!!!!!!!!!!!!!!!
I just got done reading 45 pages,..... I have a mixed review of the topic. I think there's a little blame on Ford's part and there's blame on the owner/driver.
I completly side with Ford on this one.
If you took any truck and added a prerunner suspension you would not go out your first run and jump 5' in the air at 100 mph. You SHOULD slowly work your way up to driving faster and cycling the suspension more. You would soon notice that your truck is bottoming out hard and you need to correct something.
These guys should have known they were bottoming out with the upgrade leaf springs and should have stopped. Instead they do damage and blame Ford on building a weak frame.
Tomorrow I'm going to buy a Road Armour bumper and start pushing trees down. But I won't stop till my truck overheats from me damaging the radiator. I'll blame chevy for making a weak frame too!!! :dunno:
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 453 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
