When To Do First Oil Change
I have a 2011 Silverado with 400 miles (had it 2 weeks) and was wondering what folks recommend when to change the oil for the first time. Thanks!
You will get all kinds of opinion's as to when to first change your oil. Some say leave it until the OLM tells you some will say at 3k and some will tell you now. There are even some that no sooner get it home from the dealer and change the oil. It is really up to what you want to do.
I personally change mine out on a new vehicle at 500 miles and then just the oil again at 1500 miles, then the oil and filter at 3k miles. From there it is back to normal oil changes. I have see all of my used oil analysis come back looking better when I follow this schedule then when I didn't and just left the oil in to 3k for my first oil change.
It is up to what you want to do. It really isn't going to hurt anything to leave it in to 3k. Oil is a hobby for me so I like to tinker and follow what my UOA are telling me.
To say the least
On my 2010 i changed it a 1500 miles. I wouldnt go over 3k. Everyone is going to have there own thoughts on this like oil brand or filter brand.
I do as "Black02Silverado" said on my stuff...... I change my own oil, and I always catch my oil on the first couple oil changes and don't let it go right in the catch drum..... I take a magnet and swirl around in it..... Then I cut the filter open threaded end up.... Drain all the oil I can from the media into the what is now an open can...... Magnet again this time in the oil in the filter can. Next I cut the filter media away from the filter take a clean white shop towel and begin to use carb and choke cleaner to spray the media clean watching for larger particles............ Some may say I am anal about this but....
Its all in the break-in. And break it in like your gonnna drive it.... Whether it be babying it or driving it like you stole it.
I do the same thing on rebuilt engines....... And if we have one come back in our machine shop. Your dang Skippy, I tear it down with the machinist and examine it. Metal content.... You'd be quite surprised what it would have cost us over the years over customer doing something wrong. Like the lock washer we had in the last engine that had a problem..... Thing is when it left our store it was a short block.
Jbo
If you want to follow motorcycle sbreak in routine, it is 600 miles for the first oil change. Of course, you have those who Do it several times before they get to that mileage. :thumbs:
I like to get the first one done by 500-1000 miles and then follow the OLM using Mobil 1 5W-30 and AC Delco filter. Save receipts for your records.
i do the same, but i also change my front/rear diff's at the same time. these vehicles are not assembled in a clean room..on my old 01, pulled the rear diff cover off and found a gum wrapper stuck to the inside cover..
:cheers:
Some odd reason that doesn't surprise me. While restoring a Hurst/Olds several years ago, I found a tee shirt over the head liner........ It was torn, my guess, it was removed by the man/woman installing the liner tossed on the pile of headliners and missed installing the headliner. It made it from 1979 till 2004 above the headliner.....
I have even found a termination letter in a car once.... I guess the employee got it on the line. Tossed it in the car and walked off. That was a Mustang I was changing the carpet in for a friend.
Heck, I have even seen a 460 Ford, that was missing the connecting rod cap and bolts. Piston was near the top of the bore and the rod was not protruding from the bottom of the cylinder. Engine was being rebuilt, with mounds of miles. Guy said, it always had a miss and the dealer couldn't fix it when it was new.......
A Buick Straight 8 with 6 pistons and rods. Original owner car, he commented that he removed two after the war, because parts were not available, he had forgot doing it until we brought it up after the tear down. But knew where the parts were. He never found them, ended up hunting 2 rods for a number of weeks. He was a mechanic at that time, he also noted it was quite balanced still with only the 6. So, I am guessing he knew exactly which 2 he could pull. My guess was he had one bad rod bearing and had to remove the second for balance issues.
Jbo
:cheers:
X2 on the oil. On the front and rear diff's I did mine at about 1500 miles......really just before winter. I bought the truck in August
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
