Cat Back Exhaust And Warranty
Will an after market cat back exhaust void the factory warranty?
Does anyone know where to find the warranty fine print?
I just bought my first brand new truck two weeks ago. My last two trucks had and exhaust installed and I kinda miss the exhaust tone. The factory exhaust sounds nice but I want a little more of a rumble.
Cat back exhaust won't hurt any warranty coverage unless the part itself causes a failure.
They can deny warranty on exhaust related components.
IE, if you had an issue with exhaust manfolds, exhaust gaskets, O2 sensors, cat's, be prepared for them to deny warranty on it.
They have the right to deny coverage if they feel your mod caused the failure. With the above items, it most likely wouldn't cause problems with them, but unless you can prove otherwise, you'll be on your own with them.
Dealer denied warranty an O2 sensor on my truck due to aftermarket exhaust. I could have probably tried another one to see if they would cover it, but I know I damaged it during my header install I just needed to know what code the PCM was tossing since I didn't have a reader at the time.
I haven't heard of an after market cat back voiding any warranty other than if it was the specific reason for something to go wrong. If you have any doubts just keep your stock setup and replace before you go back to the dealership if you feel like the after market system caused the problem.
I knew someone would be posting that Magnuson-Moss Act what a joke that is. Some people think with that there in the free with everything because they can fall back on it, yeah ok.
Care to explain how GM can deny warranty for an cat-back exhaust?
Last time I check GM sold cat-back exhaust made by Corsa then Borla. A muffler won't effect a FI motor since it comes after the oxygen sensors. A exhaust can't hurt the powertrain because the ECM protects the powertrain.
I guess you think wheels void a warrenty?
I doubt he was trying to say that. I'm guessing (and I agree) that people throw that bs up and think it is some shield against having to hassle with denied claims. Well plenty of people have been wrongly denied coverage and the only way to fix that is a legal battle and those waste so much time and money that even if you win you lose.
Thank you Mike for clearing that up for him.
Its a good thing for anyone to read about / know about. It's by far not a shield. Its a way for someone to be educated on what should be covered and not when altering a vehicle.
You can read about it all you want but in the end, if you mod your truck and have a failure that has even a slight chance of being related to the mod, expect a serious fight and be prepared to lose even if you're right. A member here with a 6.0 2500 had an engine failure that was blamed on a tune and other mods and he ended up winning in the end, but it took a massive fight to get there. Not everyone realizes this.
BS - the cat back is down stream of the and has no impact on the o2 sensors and cat converter. In your case, you installed components upstream and later had a problem thus the dealer denied warranty work.
I installed a cat back on my 06 about a month after I bought it new. Have never had any issues with the warranty.
So what I'm getting from all this is, if an issue arises and the after market part is suspected of causing the issue it would not be covered under the warranty. Now some people have fought and won, but that would be a big hassle. To me it would not be worth it just for an exhaust system. The reason I bought a new truck is so I would have a vehicle that would be reliable and a warranty to cover any problems without a hassle.
I'm gonna go ahead and say that nothing that could be linked to an aftermarket exhaust would possibly fail before the warranty was up other than maybe an O2 sensor. I've run cat backs on every vehicle I've owned since I was 16 and never had any exhaust problems or had any flack from dealers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
