I have an exhaust leak on the driver's side. I thought it may be leaking at manifold, but dealer said the problem is usually the first joint. I checked to make sure the 3 bolt flange was tight. It may not be as bad now but still leaks. Exhaust wrap?? Would a small leak cause less low-end torque?
Hopefully I have fixed a couple things on my truck to make it perform slightly better. First was a double win! I was taking off my OEM intake to install my Airaid Jr. and I found it had muddy water in it. So with the new intake and absence of water, I should be better off.
I swapped my 3.42 gears for 3.73 which is a plus. But I swapped my stock tires for slightly larger BF Goodrich KM2's which are pretty heavy. I don't know if the gearing is enough to offset the tire difference or not.
Lastly I uninstalled my Hypertech and am going with the BBP tune!!! Can't wait after reading all the good things about it.
Johnny
If I was gonna get a 6.2L, how many miles should I not go over if to buy one?
When I bought my '07 5.3L it had 102 when I bought it, never did use any oil at all.
Edited by STINSAN3
I remember the spacers on the old throttle-body injected engines didn't do crap. Actually, they made them lose power. Don't know why people still bought them ...
I'd imagine the same is true for these new ones, although there's no fuel going through the spacer like the old ones, so maybe that changes things ...
I'm sure somebody on here has tried one and can post better info than I.
I've read posts on other forums referencing when installing TB spacers on certain Ecotec intakes they will not work correctly unless you grind down a hump or rise just inside the TB flange. I cannot speak to accuracy just passing along.
I bought a 2010 Denali Yukon with 6.2 and this morning I heard a tapping or knocking noise on cold start...didn't hear it till today and I just bought it used on saturday! Is this typical? Wife took it down the road and I could hear it as she passed and it has been running a few minutes by then. I put regular fuel; it is a flex fuel engine. 59,000 miles. Not sure if it stopped later or not.
My 2006 with L33 aluminum block taps/knocks as well but this was a little different. The 6.0 in my 05 2500 work truck makes no noise at all! What might it be? Thank you.
Not sure what fuel the L33 takes as this thread is for the L9H version. I assume premium and since you used regular could be spark knock. Run it empty and put the right gas in it and see what it does
Ryan
I have an exhaust leak on the driver's side. I thought it may be leaking at manifold, but dealer said the problem is usually the first joint. I checked to make sure the 3 bolt flange was tight. It may not be as bad now but still leaks. Exhaust wrap?? Would a small leak cause less low-end torque?.....
Johnny
I have an 11 1500 6.2 with 98k miles. My exhaust manifold on passenger side was cracked and they replaced it under warranty. The exhaust leak did not affect my low end power.
Also replaced broken engine mount under warranty as well. Happy owner!
My 2011 runs pretty rough when I first crank it. Other than starting right away, you may even think it's not fuel injected the way it runs for a couple of seconds. Then it runs smooth with only a small yet aggravating exhaust leak. No codes. I'm guessing this isn't typical.
I need some advice. I just got my American Racing Headers and am looking forward to installing them in the near future. I just want some pointers on getting them to seal and stay sealed. I have only put headers on my old Jeep and the were always leaking. These ARH's are way better quality then anything else I have ever had but any help would be great. The aluminum heads worry me too. Do I put anti-sieze on the bolts? How tight do I torque the bolts? Any info would be great.
Buy new stock ac delco gaskets. Didn't use anything else. Did this with my camaro. Not sure what torque is for the trucks.
Ryan
Thanks for the quick reply. I have them in hand now. Wish me luck.
Post some after video. Headers would be awesome
Ryan
I still have factory exhaust on 2011 Silverado 1500 with the 6.2. Been looking into headers and read a thread on Performance Trucks of an owner removing LT headers because of mechanical noise made more audible after installing headers. Several other members chimed in and agreed they have the same noise but most were not concerned. I have a C5 Corvette with headers and the they definitely bring out more noise from the internals but the previously mentioned thread on Performance Trucks indicates that the noise on our trucks is louder than other engines / apllications. Can anyone here comment on this?
Edited by NemesisC5
I tell people if your worried about noise, leave your exhaust stock.
Not an answer to my question, I'm asking about mechanical noises on the L9H being louder than other engines.
If you can't help with contributing helpful information please refrain from "if God meant for men to fly he would have given us wings" type of answer.
Don't get your nylons in a knot - I misunderstood your question! GEESH ....
BUT .. headers are inherently going to make the vehicle louder, so ....
Edited by Jsdirt
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
