sugtions on misfire
hi guys have a little prob i hope you can help
96 silverado 350 injected122000miles aprox
seems to have developed a misfire on start up when hot all sounds right havent done any checks yet
but plugs are pritty new and leeds as well
i will try some injector cleaner and check / clean plugs may be new ones
i have a suspision its a burnt valve but cant see why it goes away when hot
truck does stand idle most of the time
thanks in advance for any help or sugestions
Maybe ohm out the plug wires. I just had one go bad all of a sudden. At first it was intermittent, then constant.
plastic manifold do they have that problem
Yes they do. Many have had to replace the intake gaskets. Since you have the problem cold and not when hot, intake is one thing I would look at.
