Who loves single cab/regual cab trucks ?
is the wheel base shorter on a reg cab . jsut seems to me they make the box smaller on cc and ext cabs if you need more weight just put some in the back of the box .
The wheelbase on a reg cab standard box is 119". The wheelbase on a crew cab is 143.5".
Sounds like you get a lot behind your seats... you must sit close to the steering wheel. :) Also I like not having to put stuff in garbage bags in the bed. With my 3 kids in the rear I can fit quite a bit under the rear seats.
  • Replies 40
they are talking the reg cab reg box... which as posted is 119. Yes the reg cab long box (looks funnier) is longer than the reg cab reg box.
I like the reg. cab long box but now there just isn't enough room in the cab so I went with the crew cab and love it.
My last 4 GM trucks were RC/LB's.
seats seats about 2 clicks up from all the way back and not / leaning all the way back. I am 5 foot 11 . but i have notice that the bottome of my seat on the back side is concaved in a bit lol .
I was just stating the specs for morgan1986 since a Crew Cab and Ext Cab look very close to the size of the RCLB. Clearly the RCSB is shorter so I'm really sure he wasn't asking about that.
when you build the crew cab you have to choose the long box and ext cab you can choose reg box or long i think . The box is really not that long on a crew cab the actual cab takes the room up or somthing .
I love em..Its just me my wife and a lab it works fine...I also feel the ride is better then crew and extended cab trucks.Plus with a 8ft bed and tool box combo plenty of room for additional storage and u can haul 4x8 sheets of plywood with tail gate up !
why cant you get the 6.2 in reg cab trucks ....?
You can. Buy a 2500. They just want you to spend more money.
I don't think so.
6.0 only, 6.2 being aluminum isn't considered HD.
cool... you definitely get alot behind your seats. :)
Thanks for clearing that up for me buddy. :rolleyes:
I don't think so.
O ok. Didn't know that. I thought they threw out the 6.0 all together. I truly do believe the 5.3 is plenty enough power in a 1500. But then again, I guess you could never have enough power.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
