Z71 Avalanche bumper & flares
This is Not a for sale post..
I have an 08 Z71 Avalanche..I bought it a couple years ago & I never cared for z71 package...I dont like the 2tone front bumper or the fender flares "or the running boards" Last saturday I got brave "bored" is more like it & decided to just pull one of the front flares off & see if there was any paint damage under the flares..2 hours later I had all 4 flares off..I found only one 2 inch scratch about as thick as a peice of hair on the rear passenger side fender down by the mudflap...Carefully filled in the thin scratch with touchup paint & some polishing & waxing & now you cant tell there was ever any flares on it..I think I'm extremely lucky and I LOVE the new look..
My Question is there even a market to sell off the flares & possibly the Z71 front bumper skin? Running Boards? I priced out a LTZ front bumper..I have access to body shop free of charge & I'm fairly talented in Painting..So for a full conversion with Paint I"m looking at right around $260..Its been a long winter & I have nothing to do on the weekends so why not?
I just have No Idea what a complete z71 front bumper is worth used "minus grill & bowtie" or the Z71 Flares Or Running boards? Everything is in Mint condition..Avalanche only has 45k miles...Or am I better off just keeping everything upstairs in my garage? Need some feedback...
Future resale value (vehicle) would probably drop
Ryan
I would keep everything to reinstall later on when you sell/trade the truck off. Then it will be back to OEM which is usually a higher value than modified.
Come time to trade it in, the dealer won't even know it's missing fender flares and a 2tone bumper. If you don't like em, and won't ever use em, sell the bastards to someone who will and put some cash in your pocket.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
