Sweating transmission lines?
my ol c10 85 diesel burb,RIP ,!!
she had crazy engine oil cooler lines that come across in front of the fan against the rad over to the passenger side and of course they leaked at the crimp,i took them to a hose shop and they recrimped the aluminum lines to the rubber ,never leaked again till i tore her heart out and then crushed her ,,,,,,sniffle sniffle ,,anyone have a tissue ??????
she was an awesome phackin truck
You see I've thought about goin to a hose shop now, the shop I work in now actually has a crimp machine. But doesn't have the correct size die's to do the job...I just come to the realization that I will lose maybe a couple teaspoon of oil every winter...
My guy was to busy today to look at mine.. Monday takling it in for a glance.
But he told me that he has cut off the crimp in the past and put some screw clamps on there and it fixes it great. Hopefully i can do something similair.
IDK what the cost of the gasser tranny cooler lines ,i could find out in about 5 minutes on mitchell ondemand,but you have the right idea to peak under it every now and again and check it and wipe it off,
after i found out that 93 6.2 diesels came with no engine oil cooler lines from factory ,i plugged the block and pooof ,no more leak !!!
do not do that for the tranny of course ,,
the K5 dude was thinking of the older trucks having cooler line nuts to tighten,thats all
+1
Done that before too. Never had a problem with a screw clamp. It's an easy fix.
+1
thought about doin that, but I don't know how much pressure is goin thru those lines? I was thinkin using a brake line flaring tool and finding like some type of a v-band clamp...or some type of Good clamp. Just always to scared to try, they are a PITA to change without a hoist...
They are like $150 in Canada anyways...I've tried changing them..couple years ago
+1
Screw clamps and rubber hose is one way transmission coolers have been installed for years. Line pressures aren't that high.
Removing the crimps and installing new hose with clamps is how we are repairing the pickup trucks in our fleet. It's a quick easy, inexpensive repair. No way we would spend the time and money installing new lines
I heard there is between 35-50 psi in there..
TXAB-- How are you removing the crimps on there? any chance of pictures or video? Thanx in advance . You would be helping out a ton of people with some sort of instructions..
just cut the outer crimp on an angle a piece at a time and work your way around it without touching the rubber hose
clamp it and done ,,,right darral ?
isnt the crimp metal tho.. how would you cut the metal? Also would there still be pressure in the line if the truck is off and cooled down? Id hate to slip and cut the line and spray tranny fluid all over.
take the line off and with a hack saw,put the blade flat against the hose ,teeth towards the aluminum crimp ,cut down to the end of the crimp ,move the blade around for another bite
i hope that helps ,
its hard to explain,do not cut the hose
Is there going to be pressure in the lines when the truck is off tho if i take the crimp off?
My lines started leaking after 8 years/158k miles. I'll take that. I just installed new ones. It's a bear of a job, but it's doable. So far all is well.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
