You don't like Jack Russell's?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Never met one that I liked no
Sent from my SCH-I535 using Tapatalk 2
He has some of that in him too. He is an ****
he clearly dosent like you
He likes me, my brothers, and the guys I play poker with. That's about it.
A little bit
Something about super small dogs and there attitudes
Thought about driving it off a cliff. 278k miles on the original transmission and now this one has burnt fluid in it after 40k (year and a half) :rant: no slipping yet but its w/e. Rant over...
Sent from my SGH-I927 using Tapatalk 2
my fog light exploded on the right side, bought a new one.. now my offroad lights dont want to switch off so i unplugged them from relay.. my old bump stop is rubbing my shocks.. my steering stabilizer is loose... hmm what else can go wrong..
Drove to work then drove the stadium to watch the game.
Sent from my DROID RAZR using Tapatalk 2
I drove 2.5 hours to LAX then got fed up with traffic on the way back so I stopped at the Pink Taco. And then drove home
Hey mike I am filling up E85 for $2.61 :)
Ryan
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
