Is that OJ's bronco?
Ryan
Lmfao we always say that to him his wheel bearing had so much play I said hit any people lately?
Truck did great out there lift helped alot with the constant drop offs
Sent from your truck via Tapatalk
Remember flat spins are good :lol:
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Sat all day- working from home and I ate here for lunch and likely will for dinner too. Guess we'll see what tomorrow brings.
Had a flat yesterday, still had 5 psi though. Drove to a gas station and filled it up, it's probably flat by now. My buddy asked me why not get it fixed, I told him "because money". So far the list for the beginning of summer is clean everything, polish shocks, Fluid Film frame, put on new tires, front brakes and wheel bearings, grease front end, change oil, send in analysis sample, change coolant. That's the truck.
Boat: paint, redo trailer bearings, check bearing in jet drive, shape and polish intake grate fins, possibly replace (both) impellers....
I think that's about it. Going to have some busy evenings. :lol:
More deck boards, figured I'd pull on the side of the house, less distance to carry them
The I hauled a mini silverado
Ryan
Ryan your son having the mini version of your truck reminds me of the HD ad with the little boy who has the toy truck like dads as he goes around the living room hauling stuff or whatever. :lol:
Gonna have my truck checked for HIV/AIDS. This thing parked next to it
Sent from my SGH-I927 using Tapatalk 2
Well if you didn't know those are 22's haha
Ryan
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
