Well the truck and g6 was egged
At least it is warm enough there to wash it!! Egged here would have been eggcicles and left dents
It was 45 degrees when I walked out. Some of it dried
Which only strengthens our argument of California. First your brothers truck was stolen, and now egging. Marvelous...
Sent from the side of the road...
My brother upgraded and has a gm now. And I may have pissed someone off. I piss a lot of people off
I tend to do that also...
But the thing is I dont know my neighbors. Looking at the pattern of where things were thown and the missed eggs hit, I was the target.
Anyway I had the tires rotated by a shop I trust. they mainly do Tractor-trailers. The tech pointed out that my rotors are starting to crack.
I was in Vegas for Christmas and although the 65 degrees in Dec was great.....way too many dang people
was there for work Christmas, but didn't see much extra traffic than a "normal" weekend.. but i had to go there on New Years eve, and again New Years day, and that sucked.. over 400,000 extra people in town to party. so on Sunday, the roads out here (I-15) are going to be parking lot for 150 miles.. :lol:
Edited by desrtrat
Uh oh, time for your SUV rear and 05+ front brake upgrade, might as well do hydro boost while your at it lol
Finally got my CV front shaft in today. Doubt it will make a difference, but its worth a shot
Edited by rdnckhntr94
Sold the Hydroboost booster the day after christmas
Shouldn't have. I think between the hydroboost and braided stainless lines, those are what really stood out. Pedal feel is fenamonal (sp?) and I can about throw passengers through the window lol
I was cleaning the garage because I am possibly downsizing
I'm thinking about doing hydro boost eventually. For right now I just want some pads that don't dust so bad. Man the EBC stop awesome but they are a MESS!!!
Which ebc do you use. At sema I was being shown their orange
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
